If not easy fix like above with the lower cover just being loose or bent, the worst case is another example of the lower timing belt gear and washer sheilds being compressed. When this happens the balancer will indeed touch the cover no matter what as the balancer has moved further inwards. This is usually an RB26 or high revving engine problem though but can still be caused by reusing the timing gear assembly when it should be replaced.
The lower timing gear assembly compressing is precisely why Ross and Nitto developed hardened sheilds / gear that don't compress like the factory stuff.
Use  a long screw drive or something like on and use it a a stethescope and press it on to several different parts of the front covers to determine where the noise is coming from it does sound like some sort of interference of one of the front covers. What condition is your timing belt in hope its not starting to desintergrate as i dont know what condition your engine is in and how many kms it has done for the engine all of a sudden starting to make this noise i would be removing the top cover and inspecting that space and rotating the engine to inspect the belt because if it breaks you will need deep pockets to fix
When was the last time you've actually seen an RB timing belt break ? That said if you don't know the age or condition of the timing belt on your car it should be changed out anyway.
My old 33 did that right before the balancer munched itself and took the engine with it. This relates to too much limiter bashing. :9_innocent: I'd remove the balancer and have a look at your snout. If there's no damage you might be lucky.
Did what, broke a belt or the balancer reducing clearance to cover and hitting issue ?
Regarding breaking balancers I can absolutely relate. I had a stocker balancer destroy itself and take the engine with it too. Wrecked everything - cracked block, cracked crank and damaged pistons.
About 3yrs ago the timing belt shedded on my VK holden RB30/25 reason unknown belt replaced no problems since also have a r33 RB25 and never had any problem with it i mostly answere question in which i have had personal problems with VK i have had for 27 years r33 had for 15 years so i have done a lot of kms with them
If your HB is wobbling at all, its f'ked.  Think about doing a kit job.....if your water pump etc are also 'vintage' then do the whole belt, pump, idler etc at the same time [unless they have only recently been done].
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
