Hey all,
Picked up a manual 370gt not long ago. Have purchased BC BR coilovers and will be doing new bushings all round and front & rear sway bars shortly.
My car is just shy of 200k kms but she still pulls hard and feels very tight all round.
I was hoping to get your opinions on what FI route I should take.
Option 1: Replace gallery gaskets and mid mount single turbo my existing VQ37. Using SOHO motorsports' single turbo dyno as a guide, I'd be looking at approx 600WHP and 600nm wheel at 5k RPM. Ride this motor out till it dies then put in a new VQ when the day comes.
Option 2: Sell my VQ and do a VR30DDTT swap. I've been extensively researching this swap and know of 3 370z swaps, two 350zs and one 350gt (US so G35). I can't see why a 370gt should be too different to a 370z. The OEM motor mounts can be retained, I'll need a z1 adapter plate for my JK41A transmission, q60 ecu, harness, engine room harness, CANBUS module, custom intakes, lower downpipes, heat exchanger and tune. This will net me less HP - approx 450whp but more torque at lower RPMs for more RPMs - 675nm wheel at 2.5k to 4.5k.
Putting aside sourcing parts, labour and installation timeframes, what would be your preference for a daily driver/occasional track visit car?  Boosted VQ for 600WHP with a lower,  shorter, later torque curve or a VR30 with 150 less HP but significantly better torque delivery?
Any shop recommendations in Sydney, Wollongong, Newcastle or Canberra?
Would love to hear your thoughts
Al
Edited by VQ37AF
Tags
Cheers Duncan! I'm definitely leaning towards the VR as I think the torque band would allow for more fun street driving. I'm writing off first gear for both options because of traction but second gear would be way more usable in the VR because at 2.5k rpm I'm only at about 40-45 kph. Turbo VQ only picks up at 3.5-4k and at that point I'm doing 60 already.
If second gear was much shorter and sat at 3.5k rpm at 40 kph I'd go the VQ route no question. It's a shame custom gearbox gearing is so expensive.
Dyno comparisons for reference:
First is SOHO single turbo for the VQ37 and second is an AMS' "Red Alpha stage 3" for the q50/60 VR30.
What do you guys think looks better for a daily?
On 12/9/2022 at 11:39 AM, VQ37AF said:
Hey all,
Al
Well i love driving my q60 and i wouldn't go back to the v36.
But i don't drive track so.....
If actually going to track it, I wouldn't bother adding power.
Quality after market radiator and big oil cooler (pwr or setrab) as they suffer from high temps after a quick lap. My 370 gets 1 hot lap and need to back off.
If set on boost look at the BTW r35 turbo kit. As that is the best value and uses most of the factory parts like heat shields and intakes. Needs like 1 or 2 after market elbows. That way can use all aftermarket bolt ons.
  • Like 1
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
