I can't seem to find many topics on this on SAU.
So there are 2 sides to this story that seem to play out.
1. They reduce radiant engine bay heat while increasing turbo efficiency by keeping heat in the turbine housing.
2. Can cause oil "coking" of the bearing due to keeping excess heat in/around the housing
Have watched a couple of vids by Engineering Explained and the like on YT, and performance wise, they seem to work well.
Don't seem to have much real world data on the oil coking bit.
Many RB workshops run them in Aus and all over the world. Anyone have real world experiences with Turbo bearings failing due to Beanies?
P.S (i recently bought a turbo beanie and running it on a water cooled GTX3576 gen2)
https://www.sau.com.au/forums/topic/484267-turbo-beanie-vs-no-turbo-beanie/
1 hour ago, GTSBoy said:
Coking is not a thing on a running turbo that has cooling (ie sufficient oil and/or water flow).
Seems to be more related to when the car is shutoff as opposed to running? Opposing side to that is if the turbo is also water cooled, the water should in theory take out the excess heat anyway.. *After you've let the car cool down*
Similar to the BOV VS No BOV debate
I've always run beanies on turbo cars, never had an issue
+1 for reduced enginge bay temps and no melted "stuff"
Coking was a thing on old only oil cooled turbos, water cooled turbos "percolate" negating this
#Physics
  • Like 1
This part I find a bit some what controversial...
I run one, have always run them to stop things melting at the track. All my turbos have been fine, just the motors explode instead 😂
  • Haha 1
Isn't there a delta in temperature across the turbine housing? Some of that heat has to go into generating KE for the turbine no? It's probably a second order effect compared to the delta in pressure so I doubt it'll be a huge benefit for performance but it's probably not entirely make believe.
Maybe in a F1 car, but not our shit boxes to be honest.
Like GTSyoda explains, it's fark all.
  • Like 1
  • 1 month later...
I was getting concerned smelling resin from my cf bonnet, so I put a beanie on my big single, I noticed MUCH lower engine bay temps. No more resin smells.
I also noticed slightly higher ECT/Oil temps on average - By around 2-3 degrees maybe, but I do run an oil cooler so thats no issues at all.
I've just heat wrapped my downpipe and its improved underbonnet temps even further.
I still don't understand why there is seemingly so little consideration paid to heat shielding in most single turbo conversions.
Because most of these single turbo conversion guys only use it for drag racing or roll racing.
Car is on noise for like a whole 8 to 12 secs.
Put any of those cars around the GP Circuit at Eastern Creek and watch things melt.
  • Like 3
100%. Mines already shielded on the side, all the way from the ABS down to the rail, plus i have heat reflective tape all over the body by the hot side inc firewall.
  • Like 1
The way it should be done!
Most of these "Instagrammable" cars would ignite after one lap of a real circuit.
So, what's the goto for turbo blankets? What are you guys using? Asking as someone who hasn't looked into this much before.
You have this uncanny ability to make me worry about oddly specific things. In a good way. Yes, I'd like to go around GP Circuit at Eastern Creek and no, I don't want to watch things melt. Not that I'm running crazy power but stuff still gets hot.
I'm just using a PTP one, so far it hasn't spontaneously combusted yet lol... Has been two motors, plenty of heat, plenty of anti-lag LOL..
  • Thanks 1
Truck spare parts have quality beanies
Most of the aftermarket stuff is average or costs an arm and a leg
  • Thanks 1
Beanie stops paint fading on the bonnet. But it does makes the bearing housing and turbine housing extremely hot. In cases of oil cooled only or people can't be stuffed connecting water pipes, turbos run without the beanie lasted alot longer.
  • Like 3
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
