1 minute ago, IM-32-FK said:
Ok it’s settled, no need to blow more money than I’ve already have.
but the idea of high and low boost baffles me. Like I said it’s for street use. I’m going to do full send pulls now and then (probably every time I drive it) but not continuous like on the track. Is high boost meant to be unreliable, unsafe for the motor? I just want max psi without blowing the motor or f**king anything.
also I’m guessing the link can is plug and play onto the ecu, just needs 12v and ground?
Your high boost setting should be tuned to be completely safe to use. Your ECU should have engine protection setup so that you shouldn't have to worry about anything blowing up if something was to go wrong. (but hey, not all tuners bother setting up engine protection. My car had a Haltech pro plugin when I bought it, and whoever tuned it previously didn't bother setting up any engine protection).
Just had a quick look at the Link CAN gauge manual, looks like it's just the normal CAN wiring and an additional +12 volt if you want the gauge to dim when you turn on your headlights. Very easy to wire up.
14 minutes ago, IM-32-FK said:
@Murray_Calavera
So also I got a blitz 3 port solenoid. Does this mean I connect the 2 factory solenoid wires to the solenoid? and since it’s a plug and play ecu, I don’t need to wire it straight to the ecu?
For example, so something like this has 2 wires coming out of it, those 2 wires connect to the factory solenoid wires in my case of the pnp g4+?
https://www.efisolutions.com.au/3-port-mac-valve-boost-control-solenoid
Yep, use the factory wiring. I haven't checked the pinout for your ECU, but I'd be amazed if it wasn't setup to use the factory wiring for the MAC valve.
There are lots of uses for a low/high setting. Low is for city driving and still having a good time then high turns everything on does just have to be a low/high switch. Options are almost endless.
Dont over think it keep it simple
Canbus keypad solves all these issues with 1 or 2 stages or rocker switches (ewww).
You could setup a few different power levels and different rev limiters on your keypad.
5 hours ago, GTSBoy said:
Low is for when it's raining, when the car is at the tyre shop, etc.
Right foot is for when it's raining. Lots of 20+psi tunes have a 14psi spring, which 14psi is going to be plenty in wet/slippery times.
Apart from a higher setting for street daily runs / drag runs, and then a lower setting for track use / long mountain runs, I PERSONALLY don't see the point in multiple boost settings. And that's coming from someone who used to run multiple settings...
Fuel economy again for daily, just go light on the throttle, and dont even bring it fully onto boost for what you'd have as the low setting... Means right foot controls boost, and fuel usage, and means if you want POWAH!, that you just flick your foot, not a switch and your foot.
  • Like 1
4 hours ago, MBS206 said:
Lots of 2 bar+ tunes have a 0.5 bar springs, which 0.5 bar is going to be plenty in wet/slippery times
4 port solenoid dis dat, just run them at lower frequencies and you have decent control.
FWIW I go from 0.5 bar to 2.0 bar with ease (just can't hold 2.0 bar past peak torque because out of compressor).
What frequency do you run yours at?
do testing using an air compressor as a pressure source. try different frequencies and see what happens. plot it in excel
It tells you things!
I run a volume of air  downstream of the valve to keep the crazy pulses in check . (3 port valve)
If memory serves me correctly I dropped it to 12hz.
Any higher and every 1% of DC was moving like 0.25 bar of boost lol.
For you that's probably the case, the beauty with building cars is we can build what suits ourselves and we're not all forced to the same path.  I've been around heaps of multipurpose builds that a single boost target configuration would not suit at all.
If you have a car that is a weekend car that at events will run drag tyres and has potential to make a cr@pload of  power but is still road friendly enough to be used for road trips etc then you really don't want to run the "run the quickest time you can on a drag radial" tune when you're going for a road trip on New Zealand running normal street tyres, I understand the "right foot" argument but straight up - sometimes when you're going to be driving for 9 hours on varying road surfaces, windy corners etc etc you don't want to have think about how much throttle you can give it every time you catch a campervan or truck with a small passing opportunity on a windy road.   Maybe I'm a pussy, but I like having the option of just being able to roll on the throttle and blow past things without worrying about the car getting all frisky if I'm too heavy footed - buuuuuut also reserving the option to go "Screw it, I want to overtake a line of cars baking the bags" :D
  • Like 2
well should i use 3 or 4 port solenoid for the external wastegate?
A 3 port is much easier to tame, a 4 port can be a bit harder to tame.
Took me a while to get the boost curve I wanted on the dyno with the help of Alex at Birrong Automotive. He advised to keep dropping the frequency in order to give more control.
like this setup?
image.jpeg.3f598692b4a8065ddb8fe0aec597b
22 minutes ago, IM-32-FK said:
like this setup?
Depends on valve type, but that setup would be easier to control boost.
Most will use this style of MAC valve.
And you would plumb it like this
@Dose Pipe Sutututu
ive currently got this blitz sbc solenoid, but i might as well get a mac valve. I see alot of brands copy the original MAC design down to the colour, like innovative and turbosmart. Which one do you prefer? the innovative ones says its 'high resolution. what fitting style do you use?
oh and also i used to work in yagonna, right by birrong automotive too. I got them to replace my speed sensor and clutch master cylinder way back like nearly 10 years ago
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
