I run a 4 port solenoids, however I don't recommend it for everyone.
In the past when I could be bothered working on other people's car for beer and cash I would generally fit 3 ports sourced from efisolutions aka taarks back in the day.
https://www.efisolutions.com.au/3-port-mac-valve-boost-control-solenoid
2 hours ago, IM-32-FK said:
what fitting style do you use?
I actually fitted 3AN Teflon lines from the valve to the wastegate.
Had too many issues with hoses popping off at the track so full sent it with AN fittings.
And Birrong Automotive are great, love their RBs.
  • 3 weeks later...
just a couple more questions:
- i was the told the r32 tps is better than 33/neo tps because it has a 'longer/bigger/larger' pulse and that i should run that instead
- was also told to run a slytech 2 wire universal iacv too instead of the stock iacv on a plazmaman plenum because the coolant spring in the stock iacv can cause problems
anyone care to advise?
Not sure what ecu you have again but if it's capable, why not just go DBW throttle body. No need for iacv and probably TPS too. I'm sure @Dose Pipe Sutututu will be here in a moment to say exactly this.
  • Like 2
Throw the TPS, cable throttle, idle control valve, aux air valve out and go DBW.
I wish I did this sooner, superb idle control, no issues with big cams and AC, etc.
Not to mention you can now setup cruise control too.
  • Like 2
ok i bought a plazmaman inlet with a 74 dbw, but that means i need to buy a link g4ret and also need to buy a pedal and mount so it comes down to paying like $500 more compared to throttle cable setup.
it better be worth it.
Edited by IM-32-FK
  • Like 2
WTF does that even mean? Is he talking about the deletion of the idle switch in favor of voltage-based idle detection? All standalone ECUs to my knowledge ignore physical idle switches.
If you want DBW to be worth it just add cruise control and traction control to the tune, maybe DBW-based rev limiting to get a no-compromise soft cut while you're at it. There's more you can do but those three alone are pretty big headline features you can do "for free" that are kind of a disaster to implement on traditional cable throttle. In theory you can also implement tricks like automatic rev-matching too.
  • Like 2
Nice! I’m yet to get my car with the new DBW setup tuned but already is definitely worth it! Check out www.iee.nz they have dbw pedals that fit stock location and stock pedal pads for that true OEM fit, he also has the right size rubber grommets to fill the cable hole. I wish I found them before I went the 350z pedal with adaptor route… are you keeping the factory oil/water heat exchanger?
Edited by R3N3
  • Like 1
It better be worth it.
It is, especially when you can control the pedal curve, which cannot be done on a traditional setup unless you swap the the throttle wheels and that's still garbage because it's generally a fixed curve.
If you've ever driven a car with a large cable throttle you'll notice it's ver touchy at low RPMs, you can get rid of that behaviour with DBW and exponentially ramp in the DBW TP vs. your Accelerator Pedal Position (APP).
And lastly superior cold start, idle control.
so as far as im aware you can either
1- buy a bosch dbw pedal and mount it onto the chassis https://www.bosch-motorsport-shop.com.au/accelerator-pedal-module
2- Buy an adapter plate that lets you mount a 350z or BA/BF falcon dbw pedal onto skyline chassis stock position https://rbfactory.shop/products/ls1-drive-by-wire-pedal-mount-to-nissan-silvia-skyline
3-  or buy a ready built one like this https://www.iee.nz/product-page/gtr-electronic-pedal-conversion?currency=AUD
ive found the adaptor for supras to mount on the bosch dbw pedal, but i cant find one for r34 skylines
I went with the Outsider Garage adaptor with 350z/350gt pedal. My recommendation would be the iee unit.
this one? it says for r34 gtr but i got gtt. would it fit? also im guessing that doesnt come with pedal and you need to install your oem one in it? so this product just lines up and bolts directly onto the oem position
Edited by IM-32-FK
Correct. All you need is the pedal pad.
I can’t confirm if the accelerator pedal fits the GTT, but I assume it would. A quick google search shows that the pedal pad should at least fit..
send Stefan (owner of iee) a message, he’s really good to deal with and may have been asked before.
Edited by R3N3
its alright i already got the gtr metal pedal to fit gtt rod, just had to bore out the little plastic thing that sits inside the rod and the pedal
theres also this one
https://www.powertune.com.au/collections/rb26-solutions/products/dbw-electronic-dbw-pedal-suits-r32-r33-r34-gtr
To be fair. It doesn’t matter which pedal you go with, as long as it bolts up. The software manages the rest.
just check the compatibility of a GTR pedal into a GTT and you’re away
im not going to do it but im just curious, do you have an idea about the wiring? where do wires from pedal go, where do wires from tb go and where does the link g4ret fit in? i think i may need a second expansion loom.  this setup is costing me $2400
Edited by IM-32-FK
2 minutes ago, IM-32-FK said:
im not going to do it but im just curious, do you have an idea about the wiring? where do wires from throttle go, where do wires from tb go and where does the link g4ret fit in? i think i may need a second expansion loom.  this setup is costing me $2400
Wiring is pretty simple. The pedal and the throttle wire directly to the ecu. Remember you’re removing the aac and tps, so should free up some I/O at the ECU At the same time.
the pedal is essentially 2x tps sensors. It has 2x 5v, 2x signal ground and 2x signal wires. The 5v and signal ground can be common. So 4 wires total.
the throttle is essentially the same but with 12v stepper motor wires.
also remember that there is some re-routing of coolant hoses under the plenum when doing DBW. Check my build thread for info if you need.
So I’m guessing my plug in g4+ requires a link e throttle module?
https://www.platinumracingproducts.com/products/link-ecu-e-throttle-g4-g4ret?currency=AUD&variant=44179266109672&utm_term=&utm_campaign=&utm_source=adwords&utm_medium=ppc&hsa_acc=9668545500&hsa_cam=18866448471&hsa_grp=&hsa_ad=&hsa_src=x&hsa_tgt=&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ver=3&gclid=EAIaIQobChMI86K2nfmq_gIVqJlmAh37NAakEAQYASABEgLZLPD_BwE
10 hours ago, R3N3 said:
It appears so... I run Haltech, so I’m not familiar with link ecu.
Is it still okay to use the collector intake gasket, the one that sits between top and bottom half stock intake manifold? Like it was a new gasket that was put on and bolted down but the engine was never ran with it on.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
