4 hours ago, GTSBoy said:
Why would you want to f**k with the efficiency of the compressor in that way?
See also: Dose.
"Hey man make my car sound broken cause it is"
11 minutes ago, Kinkstaah said:
Sorry when I said 'defective' I didn't mean "get defected"
I mean broken, working improperly. Literally sounds like a car running bad because it is a car running bad... whats next, making the car sound like it's spun rod bearings for clout?
Rotary idle brap tune brah.
4 hours ago, IM-32-FK said:
I thought it was only a sound vanity mod
Yeah, like, just drill holes from the discharge point of the compressor wheel back to the inlet.....nah that won't f**k up the compressor efficiency at all.
It is not a smart thing to do.
So all the factory trucks and buses that have wild single note dose are running bad?
Not sure running bad and dose are related in anyway tbh.
52 minutes ago, Kinkstaah said:
See also: Dose.
Lol .. I'm not on that T51 mod band wagon.
No silly mods on my compressor cover except for a welded on cast elbow on the outlet.
Just so we're clear, we're talking about that sound that you get when you back off a turbo or supercharger without any kind of release valve?
That sounds broken to me. Because it is, in the applications that it is used. You like it, to me it sounds like someone is driving around with rod knock and thinking it sounds sick because... it's ... broken-sounding?
Plenty of high end race cars run no bov, also the 20det c33's & a31's had no bov from factory
Edited by WMDC35
  • Like 1
8 hours ago, Dose Pipe Sutututu said:
A push rod V8 with 2 valves per cylinder sounds broken to me.
All subjective 😊
It is subjective! FWIW I am on the fence about bad idling and V8's literally running like shit at idle. 😛 I much prefer an equal length header LS1 if packaging allows and a nice smooth idle...
I suppose yes, cars run no bov before they were invented. Not having a bov for the original items list for OP is at least period correct. As is the T51.
Now all we need is some frosted tips, and white rimmed oakleys and go full 2006.
  • Haha 1
All subjective 😊
Speaking of making things worse to sound better, I tried your trick of turning VCT on at idle but didn't notice any change in the level of how hectic my idle sounds. Is there anything else you played with? ...or is my VCT broken? lol
You need to punch a timing hole into the zero demand table so the motor becomes inefficient at the idle RPM.
I'll post up screen shots in a bit 😎
  • Like 1
I suppose this is adding value to this thread too :)
Note the scaling on the RPM axis too, you pretty much want to close up the throttle so the revs drop a bit quicker and once it kisses the cell with higher timing it will hop into the lower load cells and the RPM will drop again.
Also one thing to note, you want to not overly make the idle control closed loop too aggressive as it will end up hunting. This seems to work for me, however I did notice after a hot session on the GP Circuit the car was hunting a bit (I suspect I needed to close up the throttle a bit more).
Sure this is completely stupid, but so is a T51 SPL compressor mod. Some would argue modding an old car is stupid too (I agree here) and to just buy a F80 M3.
We mod these Skylines because we are not normal.
  • Like 2
On 12/11/2022 at 8:02 AM, hypergear said:
Nistune with Z32 AFM will be fine for the application, I would install the AFM in cooler piping.
I just wanted to bring this slightly back on track, and also disagree slightly with Tao. If Tao was talking about the Z32 AFM in the cooler piping - I would not do that. The old Hitachi plastic tube AFMs are not supposed to be put into pressure pipework. They are not really mechanically strong enough for it. The modern card style AFMs are easy to fit to pipework and everything about that installation is strong enough to handle boost.
Funny that back in 2008 my blue 32 I had a Z32 AFM in the pipework after intercooler with a Power FC pro and HKS T51. Not the entire AFM, just the hotwire sensor part in the alloy pipework and was setup like this from Japan. The car actually ran really well with it running 28psi and mid 10s on 98, but still got 10L/100km.
Then the stock 20+ balancer failed and destroyed the engine 👍
But still...it did work.
  • Like 1
3 minutes ago, GTSBoy said:
Hack up and epoxy bodge job? Nasty.
Not quite that bad with epoxy, but cut just enough to allow it to sit on the pipe then hose clamped around the pipe either side of the remaining curved section sealed with a rubber gasket. Didn’t leak!
I suspect it was done to have the launch control on the Apexi pro ecu as there was no pro d jetro map sensor version.
How times have changed.
Just now, GTSBoy said:
That actually sounds worse!
Don't you dare say that about precision Japanese engineering !
It does prove how much a single Z32 afm could handle though
  • Like 1
  • Haha 1
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
