8 minutes ago, Duncan said:
you chuck the boost controller unit and keep the solenoid and its plumbing. Attach the solenoid to the wiring in from the stock location (extend the wires if necessary).
So you’re pretty much saying terminate the stock solenoid wiring into the blitz plug and plug it into the solenoid?
if I want a high boost and a spastic boost setting, is that done with a missile switch?
Before setting up said missile switch, have a think about a CAN keypad instead.
https://linkecu.com/link-can-keypads-have-arrived/
42 minutes ago, Duncan said:
Yes, and Yes. The boost switch would need to be wired into a spare input in the link
What is the highest safest reliable kw I can get out of an unopened det neo with only arp head bolts? Is 400kw pushing it?
absolutely no idea.....turn up the boost and find out :) Neo is apparently a good head
I guess you will need cams at that level though, not sure if the head studs are required
Nah there was one guy running like 800hp with stock neo cams.
and yes you do need head studs because the stock ones start to stretch around 300-400kw
No stock engine is reliable up there but it can be on the edge of reliable if your not belting on the track 24/7 and you have the oil situation sorted
You dont need cams for anything really but it makes it more efficient and effective But yes on the edge at that power level where they may or may not be advantageous vs response etc
350rwkw ish is perfect and very fast car for street and even track if you set it up for that
As someone who put a good 5 holes in the side of stock bottom end blocks its usually either the rods/ rod bolts that go or the bearings due to insufficient oil system
And then after all this your going to have to have your tuna manage your torque because your going to want to mash your foot on the loud pedal and it has to not knock the tyres off to go fast fwd not nowhere
Edited by bcozican
  • Like 2
So a quick update, the G4x turned out to be a g4+, an older model. He was kind enough to send me back $250. Are there limitations  for the user with the g4+ compared to the x?
6 minutes ago, Ben C34 said:
G4+ will absolutely do everything you need. No worries  .
Link product page says
 A faster Micro controller - meaning your engine will run smoother, accelerate faster and act more responsively. An upgraded Communications Chip - sees download speeds 16 x faster than G4+ 512 Megabytes of data logging - this is over 100x the size of prior Link ECUs”
it states there you can get better power and response from the g4x. I’m guessing the other features just makes tuning easier for the tuner, but doesn’t affect the final outcome?
Engineers Hat On: Knowing the speed that Microcontrollers operate at, back in the day, and these days, if Link have found a benefit in the quality of the way an engine runs by moving their code to a faster MCU, than Link needs to get it's engineers to go back and make their code more efficient...
  • Like 1
i might as well get a ffp too since ive sunken so much money into the car. $2100 with slytech iacv, r32 tps, 3 inch tb and a longer accelerator cable
i calculated the total cost after i sell the stuff i know i can sell(nistune, power fc, walbro etc) and it comes down to $18175!!!
and i bet im still going to need to spend another $500-1k on some little things that pop up.
Is this normal to get like 360-400kw?
too late now, cant go back😬
13 minutes ago, Murray_Calavera said:
Sounds like your paying for labour and paying a tuner?
labour is surprisingly cheap at $3000.
the tune however, is 2.2 for a flex fuel tune with boost control settings
so about 13-14k for parts
getting the best parts though like garett, 6 boost, plazmaman, bosch etc
Edited by IM-32-FK
Would you consider learning to tune yourself? It's not a hard skill to learn.
i dont know absolutely everything about cars and exactly how it all works, although id like to think i still know alot. It seems like a very long learning process that'll take years
If you have a cheap laptop and are willing to learn, you could be tuning within a week or 2.
I'm a very strong advocate of people learning to work on and tune their own cars. You save an absolute fortune (in your case you save about $5,200) which can be used on more parts/tyres/fuel/track day fees.
I'd like to say build the car yourself, but that's easier said then done. Not everyone has a garage and tools are expensive. I get that.
But when it comes to tuning, all you need is a cheap laptop.
If your willing to learn, you can 100% do it. I'm happy to explain step by step how I learnt to tune. I'm sure there would be others here that know how to tune that also would gladly share their experience. I'm happy to share maps and for you to send me maps for feedback as well. Again I'm sure others here would do the same.
thanks for the offer dude but currently i dont trust myself at all to tune it, i might just end up blowing something in the motor.
in the future, with my current setup, ill probably just need to change the turbo and do some minor internal work to get maybe 500-600kw. I think i might tune it myself then (maybe)
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
