Put a new battery in. Then went to put all the connections on and it just pops. I'm going up there tomorrow and will suss it out again. We replaced the fusable link small connection about a month ago because it was doing the same thing and it fixed the problem. Now it's doing it again.
Model # of old battery? Model # of new battery? Photos?
Next, seeing as it sounds like a pretty severe short, have you considered putting a multimeter, set to continuity/resistance, onto the main +ve battery lead** and seeing if there is much resistance to body earth?
**without the battery being connected, of course, and with a new fuse in place.
So basically there is a short circuit in your wiring downstream of that big fusible link, and if you can get a battery terminal to smoke it is big enough to burn your car down.
I'm not familiar at all with the 31 battery wiring so I can't suggest specifically, but you need to start pulling apart wherever that link goes (eg into a big fuse box of some sort and have a look for any sign of burning and/or very exposed wires. If you have a multimeter and it goes to a fuse box, you can pull each fuse and check if the socket has continuity to ground, but as you are blowing the big fuse not a small one first, it is most likely between the big fusible link and wherever that starts splitting out.
BTW, double check there is no chance your battery terminals are around the wrong way, that might do this....
Thanks. I'll be up at my son's tomorrow night and will send through pics on what's happening.
We had problems at all until we charged the battery and reconnected it and it happened. Tried another battery and same thing.
On 28/12/2022 at 2:57 PM, MattBas1975 said:
Hi, can you tell me what this is connected to from the battery to dash? We've disconnected it from the battery and no spark or fuse blown.
On 13/12/2022 at 4:59 PM, GTSBoy said:
Probably reverse charged the first battery, blew the crap out of everything when it was hooked up, then with the crap blown out of the alternator, any new battery will make the same smoke show?
Nope. Not even close. Power wire with inline fuse that's connected to the amp in the boot was the culprit. Disconnected and turn over 1st go. Bang O'
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
