  • Replies 86
I'll come round and install it for ya Shell :D
Really?? are u busy on Friday? *bats eyelashes* hehe :)
ed...yep i have bigpuddle :(
i've tried setting it up in both OS9 and OSX done evrything it tells me to do, and it says it's all ok - except for some problem with my connection to the phone line :P
and i know my home ph is ok cos another tech person on these forums looked up my number for me, to make sure it was ok for adsl.
ed...yep i have bigpuddle :)
shell... pm me your adsl phone number and i'll check the line for ya... gotta make sure your line has adsl codes on it. and what type of modem do you have... coz its easy to set it up on OSX. you dont even need to run the cd unless you want the modem in router mode. if your happy to have your modem as bridged... then all you gotta do is set up your network prefs.
lol as you said good luck in actually using it for the full month lol you will have to turn off all pictures on sites haha
another 30 bucks a month and you can have unlimited d/l's ..
so $29.95 for 200mb d/l
or $59.95 or unlimited
both on 256/64
haha i don't care how it's set up :P if it works then I'm a happy girl :)
Sending you my number now Ed - Thanks for this!!
oh and the modem is the one Telstra sent me...Alcatel Speed Touch 530
I got that one :P
I got that one :P
your line is all good shell...
hmm how is your modem connected?? USB or ethernet?
USB wont work on a Mac so you gotta connect thru your NIC
how many lights you got on your modem?
Ah stuff it, i'll type it up from memory.
Mac OSX up to 10.2.8
SETUP:
From wall socket -> Modem, run a phone cable, either through the filter/splitter, or straight from the wall.
All other phones in the house need the Filters attached to them.
Run the Grey CAT5 cable from the 530 to the MAC into your Built in Ethernet. This cable looks like a phone cable, but a bit larger, has clear ends.
CONFIG:
Once plugged in, and the modem is powered.
Click the Apple Menu -> System Prefs -> Network.
Select 'Built In Ethernet' from the 'Show' menu.
Click the PPPoE tab.
Fill in these fields, 'Bigpond' as the 'provider', your username in the Account name field, followed by @bigpond. (if e.g. shelly@bigpond), password in the password field.
Tick the 'Show PPP status in menu bar' box.
Click on the TCP/IP tab. In the 'Search Domain' box, put in nsw.bigpond.net.au
Click Apply now. Close the Network Config window.
Now, open Internet Connect either from the Dock/Status in the menu bar, or through the Mac HD in the Applications folder. Change the 'Configuration' box to 'Built in Ethernet' if need be. Click connect. If all goes well, Connect will change to Disconnect, and you're away.
See if that works.
Ewen you legend for typing all that out! :)
when i type in my password (4 digits) and click apply, it changes it to something (dunno what!!) with 8 digits???
the password in here shows up as 4 digits...i hit connect...get an "authentification failed" :)
and my modem icon in the dock still looks like this (pic attached)... which I'm sure is supposed to mean there's something wrong with phone line connection...
i followed exactly what u said Ewen, I haven't got the USB plug in, and i've got 3 of the 4 lights happening on the modem....dunno what the hell i'm doing wrong!! damn this blonde hair LOL :P
Ewen i'm only running 10.1.5... furthest i could go with free upgrades cos my iMac is a few years old now.
Ed... i don't get what you mean? my password has always been 4 digits with my bigpond dial-up...should they have given me a new password for adsl?? And i don't think the account is disabled cos they're charging me for it!! i went on a 24 mnth contract when i signed up.
aaargh it's all to confusing...Ewen, you're gonna havta come & help me!! :D
Okay, when you received your Self Install Kit, you would have also received an email confirmation that had your new ADSL username and password in it. Different from your dial up one. If you ring 133933 they can tell you/reset for you, the password and tell you your username, just to confirm it. But if that's still not working, i'll pop round and see what can be done.
Shell... looks like thats your prob there.. your username and pwd..
you would have been given a new username and pwd for adsl... if you didnt get it then call that number ewen gave you... then you should be connected..your dial up username and pwd are not valid with adsl.
Something not to do with your connection.. im coming down today... anyone gonna be at work? be there prolli bout 3 or 4 ish... i'll drop by teletech anyway
well...where would i be without you guys? :grouphug:
THANK YOU SO MUCH!!
you're right...i should have a new username & password (which I was never sent - even went thru all my emails to make sure!)..
went into a telstra shop today to get them to set up the WAP stuff on my mobile and i asked about it and he said the same thing...so will get it sorted soon :P
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
