Where can I go to  replace  a remote ignition key which activates an alarm system and also  opens and locks the. doors ?
The key was stolen but we have a duplicate which engages and disengages the alarm system , locks the doors and starts the car .
I am not even sure if what I have was standard  for the NM35 or is an aftermarket alarm.
If after market it was installed in Japan.
I have a short  black thing  on my key ring( a RF transponder??????) about3 cm longhand 10mm wide which has to be near the ignition for the car  to start
 I have a personal import NM 35 so the Nissan dealer doesn't want to deal with this vehicle
regardless of the issue.!!!!!
thanks in advance
When you say "personal import" do you mean you are aware of all the importing steps and no-one added the transponder in Australia? We had a fob like that on our old Cube which was for an immobiliser installed by the importer (Just Jap)
If you are certain that fob was on the keys in Japan then it is a bit trickier to find someone local who can help.
In any case, if you want a single fob to remote central lock and immobilise, what you need is a competent local installer to put a new system in as your current remote central locking is on the key and the immobiliser is a separate system on the fob
Good detail!
So do you need the central locking key, the immobiliser fob, or both?  The key is a standard nissan thing from the period so just pick up a blank one that looks the same of ebay and get it cut to suit and coded at the same time (just need someone who can do late model nissans, the process is all the same).
If you need the fob, that is a question for the autowatch dealer to supply and code
    • I know this thread is quite old, but I found it, it helped me, but I also wanted to add my experience and troubleshooting finds to the chat for others. I have not been able to open the rear hatch of my 97 Stagea for several months. Figured it had just really sealed itself up over the winter and I would just get to it eventually. Well that day was yesterday. Some time ago, I noticed my battery was going flat all the time. It was frustrating. Then one quiet night in the garage, I could hear and ever so slight humming / grinding noise coming from the back of the car. It was like a really quiet popping sound or something like sand in a very low speed blender. I took off the panels in the back and noticed the noise coming from the auto close motor, so I unplugged it and the noise stopped. And the auto close was disabled. Well, fast forward to yesterday, I tried all the tricks with power and fuse and lock and unlock and I still could open the damn hatch. So I took off the panels from the inside and found the auto lock had engaged and was stuck in close position. When plugging and unplugging the fuse, I could hear the relay clicking. So I plugged the autoclose motor back in, and the damn thing let go. And immediately started making that grinding sound again. This time, instead of just unplugging the motor, I pulled the fuse, thus depowering the relay entirely. I don't have the autoclose feature now, but at least I can open the boot and not have my battery being sucked dead all the time. Not sure what caused the motor to latch when it was unplugged from the system, but I am pretty sure it won't cause any more problems now.  If anyone has a lead on a new motor, please let me know. It's a cool feature that I would like to get back.  Hope this helps.
    • Lolololol maybe, man I hate this car. Lapsed judgement a respray and a new motor, when I should have just scrapped the lot when I had the chance. Farken.
    • So you reckon a few sweety something's whispered in her window and she'll behave for me? 馃槢
    • One of the first things i do when i buy a car is to change the in cabin filter, because no one ever does. There seems to be conflicting statements on the internet, does anyone know if a 97 r33 actually has one?
    • Thankyou! I'll add a pic of my Z for good measure! 馃槢
