Rumbling engine after fuel pump change
Hi I need your help.
I just changed the fuel pump in my R32 rb20det, and took it for a drive. It was responding very well and then all of a sudden a few minutes into the drive it started to rumble. It pretty much sounds like a boxer engine now and the car shakes slightly.
I need some ideas or areas of focus because I'm currently freaking out
First things first. Install fuel pressure gauge between engine bay fuel filter and fuel rail. Check for correct fuel pressure at idle, at low load and, if these look fine, at higher load.
Maybe first things before the first thing. Take apart what you've just done and see whether you have failed to make a connection properly and something is leaking in the wrong spot. Broken wire at crimp terminal, etc etc.
  • Like 1
Agreed....and change your fuel filter too incase something was dislodged while you were changing the pump
 Share
