I haven't looked at weird things people have done to RBs before so I don't really know what to make of this. Looking at the vacuum line just above the oil filter it looks like it's looped back on itself. Checking the vacuum diagram I'm pretty sure both ends of the loop are supposed to go to the OEM boost solenoid. OEM boost solenoid is nowhere to be found but the harness connector is still present and doesn't appear to be modified, couldn't find any boost solenoid at all. Wouldn't this be equivalent to 100% duty cycle on an OEM solenoid without the restrictor? Thankfully this isn't my car.
1 hour ago, r32-25t said:
Just block both those hoses, it wide open if they’re connected
Ok, so I guessed right. Supposedly this car has -5s on it with the stock tune/ECU. Stock fuel injectors I confirmed personally. The owner told me it didn't start coming off the truck and when I checked it cylinder 4 is misfiring even at idle.
Remember stock boost solenoid is a normally closed setup and then bleeds directly to atmosphere / air filter, so if you join both stock solenoid lines together it creates one hell of a vacuum leak.
  • Like 1
1 hour ago, Duncan said:
It would be worth tracing the wastegate solenoid boost reference source too.
As far as I can tell it's there is no wastegate solenoid anymore. I'm pretty sure that the brackets that hold the OEM solenoid on are also gone. The boost reference line is still hooked up like factory though, plenum line appears to go down to the combination vacuum + coolant pipe underneath. Checking the exhaust side of the engine it looks like the hoses are hooked up to the factory positions, both the wastegate line and the pre-compressor vent line. I couldn't get a clear view of the back of the engine because the autobahn88 hoses aren't clipped down or anything like the factory setup.
sorry, misleading extra word "solenoid" in my sentence :)
"It would be worth tracing the wastegate boost reference source too"
Sounds like the wastegates are connected directly to the post throttle source, so it should just be running wastegate pressure on the turbos. On standard that is about 12psi, if these are -5 they are more likely to have come with 14psi wastegates or 7. Apparently the boost is pretty lazy when hooked up that way, normally the boost controller holds the  pressure low until near the target boost level
Yeah, I told the owner to test the wastegate manually with a shop compressor and regulated air feed or some equivalent pressure source. We'll see how it goes I guess.
No with that looped around it’s the same as having the wastegate line disconnected, they need to be blocked off
  • Like 1
Almost yeah. The problem is the boost source that goes to the actuators is tee'd before the solenoid on the hard line and as I said the other side of the solenoid vents to airfliter, so if you just join the existing lines it's like a having a massive boost bleed on the actuator line. So much so that it'll bleed off that much to atmosphere the gates will never open because of such a weak boost signal at actuators.
Yes the lines need to be capped 👍
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
