I was working on the car last night finishing up a battery relocation and when I flipped my breaker my dash and most of the interior power was gone.  So I searched the fuse boxes and found that the main fuse blew so I thought it was just a blue moon type of deal.  I bought another one and it blew.  Does anyone know what that fuse powers besides the interior fuse box its a 75a grey and clear top.  I've read some forums but not much info but some said about it grounding off the alternator so I'll put some pics of the wiring on the ALT.  This is on a new built engine so it hasn't been ran yet I'm almost done and very close to starting.
https://www.sau.com.au/forums/topic/484309-r32-gts25-main-fuse-blowning/
9 minutes ago, GTSBoy said:
Are you seriously doing this without having the car's wiring diagram? It's freely available on the internet. I even made the best resolution scans I could and posted them on this very forum a year ago or so.
Yea I seen the post but its for a 33 not a 32.
well, yes the alternator is the easiest place to get that wrong; check the wire with continuity to battery + is on the alternator + and the alternator earth is correctly to chassis earth
I realise this, but...... it's still useful. Simple things like what the main fuse runs and what the wiring near the alternator looks like don't tend to change much. Notwithstanding that, the R33 drawings are out there too.
I checked it rn and no power is going to the alt.  Doesn't the main fuse send power to it?
11 minutes ago, Murray_Calavera said:
I have a Christmas gift for you.
Yes I know there is that one but it doesn’t really have info on the main fuse 75a which I believe is not on the 33.
3 minutes ago, GTSBoy said:
Wot? This one?
oh yea I'm dumb.  I'm getting another fuse tomorrow and will check it after work I looked at it rn and the positive to the alt was pretty loose and the ground was good not sure if the pos being loose will make the fuse blow or not.  In the diagram everything looks whats on mine.  I read another forum on my ALT there is not rubber piece on the pos terminal do you think its grounding on the ALT since it touching?  In the other forum he said he just put a rubber washer and it fixed the issue.
If there's no short to earth then there shouldn't be a reason for a loose terminal to cause the fuse to blow.
Well, obviously the + lead can only touch the thing that it is supposed to touch on the alternator stud. There really shouldn't be an easy way to short the + lead to the alternator body. There is supposed to be an insulating washer on most B+ studs (and on the D+ also). See below
Bosch Alternator Terminal Pattern Name? - BoostCruising
yea both of my washer are gone i will get some tomorrow and try the new fuse
before you pop another fuse or 10, check if there is continuity between earth and the fuse socket. If there is, you need to trace through that loom and find the massive short.  You didn't just get 2 unlucky bad fuses all of a sudden.
Edit, on second check it is clear that the positive wire's terminal is touching the alternator body in your pic. You don't really need an insulating washer, just screw the existing nut down to the body (tight but not overtight) then fit the ring terminal, then another nut to hold the terminal. That will keep the terminal well off the body.
And yes, adding a boot is good practice anyway, it will stop big sparks if you are working in that area without the battery disconnected and accidentally touch the terminal and anything else with a tool
I checked it today the one prong had power and one didn't so I think its fine there or if your saying to check the ground that comes off the alternator both had no power.
What he was saying is check for continuity to EARTH at the fuse box. If one side is power and the other side is continuous to earth, then when you put a fuse in, you have a short circuit (where you really really shouldn't).
Wasn't able to get to it today also have some washers coming tomorrow will update tomorrow
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
