Hi,
If using a race/serie damper :
- without AC, no relocation kit needed, it means that the steering pump pulley is aligned with the groove of the damper
- with AC, a relocation kit is needed, I would expect only to have a bracket for the AC compressor to move it forward however there is also another pulley and a bracket to move forward the steering pump which makes no sense ?
Obviously there is something I don't catch
Best regards
I'm pretty sure I've told you this all before in another thread. The deal is with the Ross race or gold series damper they are designed not to use ac and only has 2 pulleys standard, so where the ac belt would normally sit on the balancer that is a solid dampened area and then the power steering belt runs on the 2nd outer pulley in the factory alignment. Remember the ps is the very outside belt not the ac normally.
If you want to run ac they remove the outer damper ps pulley and put an ac pulley in that alignment then bolt the ps pulley on the outside of that pulley. This has the effect of moving both the ps and ac pulleys forward 25mm on the balancer, meaning you need the ac and ps relocation brackets to move the ps pump and ac compressor forward 25mm to realign with the balancer.
Relocation of the ps and ac forward 25mm means you cannot use the factory radiator fan anymore as it will hit - I measured my r32 and R33 GTRs for Ross to confirm that you can't run the ac relocation with a factory fan without hitting the ps. The 32 was somewhere around 16mm and the 33 was less at only 12mm. I believe the 34 is pretty much the same as the 33, but anyway none of the GTRs have 25mm + down there so it doesn't work unless you go thermo fans when relocating both ps and ac.
Hence why I ditched the whole ac relocate idea and went back to their current integrated trigger 800hp Tuffbond balancer as everything lines up like factory. Take their power ratings with a grain of salt - they are conservative on their power ratings and admitted themselves you can't actually rate a balancer in power. I'd suggest just get a Tuffbond unless you want to ditch the ac.
  • Thanks 1
13 minutes ago, GTSBoy said:
Surely this is just screaming out for either an electric AC compressor or an electric PS pump to solve the problem? Guessing PS pump the lower power/easier option.
To retain ps in factory alignment I'd say so for electric ac.
Obviously to keep ac belt driven you'd need electric ps and still need to relocate the ac 25mm.
My thinking is that mech driven AC comps use a couple of horsepower to drive them. So, if an elec AC comp was in some way super efficient and only used 1500W, it would still pull >100A on a 12V feed. I think the electric AC systems are from electric cars with much higher voltage supplies available.
I agree with electric aircon being a no go from a high electrical load perspective, so with the Race or Gold dampers that brings you back to:
-Having to relocate the ac 25mm to keep it mechanical then go electric ps pump to be able to use your factory viscous fan
-The undesired approach to relocate ac and ps 25mm, ditch viscous fan and switch to thermos or
-Ditch the ac all together, run factory fan and not relocate ps.
I couldn't be f**ked doing any of those options when the Ross Tuffbond is factory alignment and will be fine unless you're looking at 700kw + or stupid 10k rpm stuff.
Thanks for all your reply !
I would prefer to keep the PS stock and elec AC is not really possible as you mention
@BK, indeed you already make some explanations but I didn't understood the purpose of the kit, now I do thanks to you
"If you want to run ac they remove the outer damper ps pulley and put an ac pulley in that alignment then bolt the ps pulley on the outside of that pulley. "
I didn't know the outer pulley was screwed to the damper itself !!! this is now 100% clear !
Couldn't we run the AC and PS on the same belt ? (so we need only to relocate AC )
Assuming ratio are ok
find in attachment some pictures of my r34 gtr
It's a lot of load for the one belt to have to pick up at the crank pulley and it would be difficult** to arrange the two pumps so that you go enough wrap on the crank pulley to do it.
**Potentially impossible to transmit sufficient torque even should you be able to locate them so that you can get the maximum wrap around the crank pulley.
  • Thanks 1
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
