SAU NSW - Sunday Sessions - Benzin Cafe - Sunday 12th February
Not only is it a new month, but a new year! So, to kick off our Sunday Sessions for 2023, we're heading back out to the amazing BENZIN Cafe!
As always, this is the perfect event to catch up with the SAU NSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter!
So now that your taste buds are tingling with excitement, make sure you save these details to avoid missing out:
Date: Sunday 12th February 2023
Meet Location: Benzin Cafe - 1/242 New Line Rd, Dural
Meet Time: Meet at 7:00am for those that want to get prime parking at the front of the shop. The cafe will open at 8:00am
Map: https://www.google.com/maps/place/Benzin+Cafe/@-33.7032661,151.0270385,15z/data=!4m5!3m4!1s0x0:0x2bab9f6d2427b9c7!8m2!3d-33.7032661!4d151.0270385
This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days.
This is an official SAU:NSW event and will be run under a Motorsports Australia permit.
One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general.
When attending one of Skylines Australia NSW events please try to:
• Be aware of surrounding environment and act accordingly.
• Drive courteously on the state’s roads as a true enthusiast should.
• Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly.
• Any misbehaviour will not be tolerated and you will be asked to leave.
Thanks guys and hope to see you there!
  • Like 1
  • 1 month later...
Photos are online now! Make sure you check them out!!
https://www.saunsw.com.au/gallery/february-2023-sunday-session-benzin
The pics are also posted on our facebook! 😁
  • Like 1
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
