RB26 OEM Boost Solenoid Valve terminals
Hi guys,
Just looked at the FSM regarding the RB26’s oem pcm valve/boost solenoid. It says valve terminal 1 and 2, didn’t say wire color etc. I’m no electrician so I’m not really familiar with the symbols. One terminal has a black verical line as some sort of symbol. Anyone can tell which is which? Because I did get a 12v output on a terminal that’s supposed to have none. 😅 Terminal one is for the yellow and blue wire, or that’s the black and red wire? TIA!
They kind of show it in the diagram, terminal 1 is the vertical part of the T and 2 is the horizontal/perpendicular.
But, why do you want to know? That Pin 1 should have power at all times when IGN is on, terminal 2 is pulsed by the ECU to control boost (ground signal)
Because I got power at the horizontal terminal with the ignition on not the verical one.
Just now I started the car, and at idle I’m getting 12v on both terminals. 🤷🏻‍♂️
There is no problem here.
Point 1. DC solenoids do not care which way that they are wired up. They throw the solenoid in the same direction regardless of current flow.
Point 2. The solenoid coil is just wire. If you put 12V permanently onto one side of it, and do not earth the other side of it, then the 12V will be measurable at both terminals. That 12V is actually measurable all the way down at the ECU. The ECU doesn't care. When the ECU decides that it wants that solenoid to operate, it provides the earth, by switching on a MOSFET (transistor) inside the ECU that will connect the solenoid terminal to earth (exactly as Duncan^ said). Now the solenoid has 12V being fed in one side and a convenient earth on the other side. Current flows, solenoidy things happen.
  • Like 3
Thanks for that detailed solenoidy reply! Just confused why the supposed terminal that’s giving 12v (ignition on) isn’t giving me any, and the terminal that shouldn’t is giving one.
If this is the case then we’re problem free. 😊 Some parts of that old FSM still confuses me.
But, why were you checking in the first place? The IGN 12v at the boost control solenoid (terminal 1) also feeds a heap of other locations like the PCV, were you trying to sort a problem or just wondering?
The wiring from the ECU to the boost control solenoid is fine for use with a aftermarket ECU and solenoid if required (change the plug at the solenoid end to suit)
I just replaced my old krusty solenoid. And since I tested the resistance of the new one, I also tested the wirings because I have a voltmeter in my hand… and I remember before that my mechanic had some rewiring done. 🙂
  • Like 1
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
