Hello everyone,
I want to thank you for any info in advance. I have searched the forum but need help finding the answer. I Have an R33 Gtst and swapped it to an RB25det NEO with NEO ECU. For the swap, I used a wringing specialties harness, and it has come together prefect only issue is the AC does not work now. I did keep all of the R33 AC components. I noticed that the R34 has a two-wire AC pressure switch, and the R33 has a four-AC wire pressure switch. Has anyone else done this or know the fix?
https://www.sau.com.au/forums/topic/484330-neo-swapped-r33-ac-help/
  • 3 weeks later...
The R32 & R33 skylines have the refrig pressure switch in series with the power supply to pin9 on the Ecu. If you press the AC button the the Ecu earths this pin and the ac compressor switches on. If the refrig pressure is low it will open circuit this power supply to the Ecu and prevent the ac compressor from switching on and damaging the compressor.
in the R34’s the refrigerant pressure switch is wired independently of the power supply to pin 14 (equivalent of pin 9 on R33) the controls the ac compressor operation. The refrigerant pressure switch provides a signal to the ecu at pin57 to tell it the refrigerant pressure is ok. Without a signal the ecu won’t Switch the ac compressor on. The plugnplay looms I have done in the past for this swap have included a small power feed to pin 57 to make the ecu think the refrigerant pressure is ok. I use the 5v power from pin48 through a couple of 2.2kohm resistors to drop the voltage to approx 2.6v.
The alternative to this is to install a switch in the cabin that simple earths the old pin9 to manually switch the ac compressor on.
  • Thanks 1
Thank you for this information, I greatly appreciate it. When you drop the voltage on pin 48 to 2.6v are you connecting it to pin 57 Or does the voltage just need to be dropped inline to send the signal to the ECU ? Thank you again for your help.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
