Been having trouble looking for cams that would be good for a 20e and was wondering if I could use 20det cams in the 20e (yes I know it is SOHC just wondering :))
not planning on swapping the engine, just wanna have some fun with the 20e
  • Haha 1
https://www.sau.com.au/forums/topic/484353-can-rb20dedet-cams-fit-in-the-20e/
35 minutes ago, lucidz32 said:
I was wondering if I could use a single cam from the de in the 20e?
Since there are barely any performance 20e cams available
I'll keep it simple, the answer is no.
  • Thanks 1
No, you cannot. As I said above. A twin cam engine has the lobes for the inlet valves on one cam and the lobes for the exhaust valves on the other cam. A single cam engine has all the lobes for all the valves on the same cam. There is absolutely no way to make this work going in either direction.
  • Thanks 1
rather than worrying too much about cams, what are you trying to achieve and what sort of budget do you have?
you can potentially increase power 4-8% by a freeer flowing intake and exhaust for under $5k
  • Like 1
Hmmm, I am somewhat out of money after doing what you have said above along with a few other mods and just looking for any solution where I can have better cams on the 20e 🥲
Sorry if I seem uneducated, I am fairly new to this 🙌🏼
Cams are unlikely to be a practical answer with no budget. You will need a custom cam ($1k) plus a tuned ECU ($1-2k) and still probably the intake and exhaust mods ($2-3k)
The unfortunate reality is that no budget to modify a non turbo car will result in no improvement (mostly likely outcome will be less power, rough running and bad fuel economy)
  • Like 2
Add turbo, enjoy life. If not turbo, add supercharger. If not supercharger, add nitrous. Anything else will be a disappointment. Remember, the RB20E is a very small, very low torque engine designed to do one thing and one thing only. Which is to move cars from point A to point B at the lowest possible speed while minimising Japanese registration tax.
  • Like 1
10 hours ago, lucidz32 said:
What bad luck, imma end it with these words "my engine blew a few minutes ago" imma 25 swap it when I have enough money 🥲🥲
Word of advice. If you're a younger gent, don't try to speed up the process by buying cheap ching chong meow ebay parts. Try and find the best bang for the buck and if it takes time, it takes time.
RB20's have creeped up in price a fair bit but would also be a cheaper option then an RB25. They are fine for 300-400whp. Cheers.
  • Like 1
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
