Before i buy injectors and fuel pump etc and leave the car for tuning, which size of injectors would you go for?
I think i want to run as low power as i can with the GT28-5 turbos. But would be nice to have some room for more maybe.
I have OEM injectors refurbished and cleaned but they wont probably be enough as someone mentioned here before?
Fuelpump about 255l/h - 340l/h?
something else you would change before tuning the car?
Setup:
Rb26dett with
-twin GT28-5 turbo
-JE-pistons 8.2:1
-Eagle H-Beam rods
-ACL race main and rod bearings
-Oil pump collar installed
-Older verision of LINK G4 ECU
https://www.sau.com.au/forums/topic/484357-rb26-setup-power-and-injectors-size/
19 hours ago, Dose Pipe Sutututu said:
Why are you choosing to go with such low compression?
I actually dont know. These was ordered from Realstreetperformance, and i belive i had these recommended by them but i could be wrong. Could be the the guy building the engine that told me to get these ones as well.
On 12/01/2023 at 7:32 AM, djr81 said:
Assume you have the ballast delete and a new AIT sensor? Plus someone who can tune TPS?
Thank you for the reminder about the ballast delete.
AIT? Do you mean intake air temperature sensor?
Well, i guess the tuner can tune the TPS 馃槵
On 11/01/2023 at 9:04 PM, GTSBoy said:
Just go straight for 1000cc Bosch ID14s from somewhere reputable. A ~340L/h TI pump would be fine. Wired properly, of course.
Okey, thank you. How lower power could i run with the 1000cc:s do you think? How much power can the engine handle? I do not want to push anything. :)
I will re-wire the fuelpump! Thanks for the reminder.
Stock. If it will idle on an injector (and of course, with a decent computer, the engine will idle on 1000s) then it can run ANY power level above that (up to the limit of the injector capacity, of course).
Most of your list of engine mods would contribute to being able to run up to the limit of what the turbos can provide - except for one thing. I would not attempt to do so without a significant oil pump upgrade, and then paying attention to the engine breathing and oil draining situation - as per the oil control thread (or the last 100-150 pages of it anyway).
  • Like 1
Send them back and get a higher cr.
Yes for the air inlet temp and not what I meant for the tune. See here. Some tunas talk a good game but individual throttle body tunes are beyond them. Where abouts in the world are you?
  • Like 1
3 hours ago, GTSBoy said:
I would prefer being able to stop for fuel anywhere I like rather than the fuel stations with E85 being 15-20km apart.
Hence full flex allows just that, depending on fuel choice your power will vary.
When you feel like a 20 year old fuccboiiii and want to race people on the street or actually go to a race track then fill it up with E85 then top up the tank with 98RON for your commute with whatever ethanol is left.
Exactly what I do having the cars on flex, and I live somewhere where E85 has to be drummed up.
True that so many tuners want to try to tune individual throttle RB26s with MAP because they don't understand TPS fuel load and then get poor results.
One of the many reasons I went to Simon at Morpowa as one of the few who I had confidence in to do it on fuel TPS load with the Haltech.
  • Like 1
42 minutes ago, reallyspeedly said:
Is there any good reason for this? It's too late to send them back, the engine is built awhile ago already.
Well if the motor is built then it's built.
There are many good reasons for higher compression ratio though, more power at all rpm, increased turbo spool, better off boost performance, more low end torque.... I could keep thinking of ways to say "the engine will perform better, everywhere" but you get the idea.
  • Like 1
Yeah, i was sitting here and realise that. Well this car got really shitty.. wrong turbo setup, wrong pistons, ecu, etc etc..
i guess i have to ask the engine builder about this, cause for some reason he installed them and this guy is really good with what he's doing.
Edited by reallyspeedly
Turbos are fine, just a bit old school as the hipsters have diluted their gtr purity and gone for singles. They are still good units, however and the blokes with ponytails and beige Volvo dailies can get stuffed.
鈥楾he ecu is a good ecu. You just need a good tuna to tune it. My point wasn鈥檛 to put down the setup just to highlight you need someone familiar with rb鈥檚 and their idiosyncrasies.
.3:1 isn鈥檛 earth shattering on the cr. Certainly nothing E85 won鈥檛 compensate for in spades if you go that way.
So yeah don鈥檛 get negative about it. It will work fine and be loads of fun. FWIW I鈥檝e got -5 turbos and a Link ecu.
  • Like 1
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
