Z32 or R35 AFM
Looking for suggestions and opinions
  Rb25det stock bottom
Tomei camshaft 264 and 8.5mm
Tomei adjustable cam gears
Arp head studs
Tomei 1.2mm gasket
  Gtx 3076R
turbo  38mm Westgate 17psi
E85 460 WALBRO FUEL PRESSURE REGULATOR 740CC injectors
Greedy style plenum NEED HELP
Option 1 80mm Throttle body
Option 2 Stock Throttle body
APEXI power fc and boost controller
  At the moment Z32 AFM and i am thinking about R35 AFM
Will I get more power with R35 AFM  And best place to install R35 AFM
1 hour ago, Dose Pipe Sutututu said:
R35 AFM, stock throttle body.
Install the R35 AFM post intercooler.
like i  draw,  red place should be good  at the photo between blow off and IAC hose
or better between  blow off  and  exit of intercooler
Edited by DDimmo
Red spot is a good spot. Before the BOV offtake is also good. In the red location you will have fewer strange fueling behaviours when the BOV opens. With the AFM in the upstream (of the BOV offtake) location you will get rich fueling on BOV release (which probably won't matter too much because this is a throttle closing/closed condition anyway.
  • Like 2
Arp head studs
Tomei 1.2mm gasket
  Gtx 3076R
If you already bought it I guess you're wedded to it but I would never recommend running a short runner intake like the Greddy/Freddy/etc
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
