My neice is getting her P's soon and needs a car. She has a budget of $5k...
I'm going to try and work with her to get more budget but if we stick to amounts around this and considering how my sister drives 😬I'm going to want something safe. Very very safe
The best I have so far is a bk Mazda 3. Preferably the maxx (two x's for coolness) or the sp23. The latter having lots of airbags, abs and traction control. For this price though they all have been to the moon a few times.
Maybe an AWD subie? An Impreza RS has a bunch of safety stuff but I'd be worried about maintenance costs and general reliability.
In Nissan's corner there is the woefully under equipped Tiida or a Micra which looks good but is tiny. Can get a auto SSS N15 Pulsar! But it has no safety features at all.
What do you think is the best option here?
https://www.sau.com.au/forums/topic/484362-car-hunt-challenge-5k/
When it comes to crash safety, I think the most important factor is having the bigger car in the collision.
If a 100 series Landcruiser with a bull bar and a late model Mitsubishi Mirage were involved in a head on collision, I would much rather be behind the wheel of the Landcruiser, despite the Mirage being 20 years more modern with a higher safety rating.
Having said that, my vote would be for a mid 2000's Camry/Falcon/Commodore/etc. It's the best combo of large vehicle/modern vehicle that I can come up with.
  • Like 1
Mazda 3 is my vote, we've had ours 6 years without any trouble, regular servicing and she goes and goes and goes.
They're bulletproof. If you do look for a BK and it's automatic, the only thing that could fail with them is the TCM, not an expensive fix but something to be mindful of. Very safe car too.
  • Like 1
Maybe one thing to consider is that you have to be quick. At least on carsales a good deal in that price range might be sold literally within the hour. The ones that are still listed are the ones that don't sell because they are priced too high for what they are.
It needs notifications enabled in the app and funds ready and basically be willing to put on a deposit straight away with no questions asked.
I found it depressing when I was looking a few months ago. Also because I imagine that a lot of them get sold to people who flip them. Because what normal person buys a car in that way?!
Good luck! :)
  • Like 1
10 hours ago, funkymonkey said:
100% no on any cheap, used euro. :D
Otherwise, I'll be the one trying to maintain it for her ...
1 hour ago, PranK said:
Yeah I was thinking about just getting something big. Not sure how keen she'll be on that.
Territory is not big big like a Cruiser and actually feels a lot smaller and nimble behind the wheel than you think. Lots of safety gear for the time - remember they were Wheels coty when they came out.
My missus drives our AWD one around like its our Rex.
If size matters for a first car, Toyota Camry, boring, but excellent
I bought my daughter a Yaris because she wanted a little car that was cheap to run, she has not had 1 issue
Well.....she did hit a kangaroo doing 80kph, she was find, and the car cost $1500 to fix
Luck, yes, but still
Yuck VAG.
I recently went through this. Hatches/small cars were heavily inflated. I found Accord Euro to be a good deal. CL9s easily go for less than $10k, I bought a base CU2 for $11k last year (130k km, serviced at Hani's or whatever that Honda garage near Cabra is called). My cousin picked up a half decent CL9 for $7k.
Auto or manual, (if looked after) reliable, can get the luxury with sunroof and HID headlights.
On 16/01/2023 at 6:14 AM, Duncan said:
Used to be you could get a R32 GTST for that budget, not so much any more
I bought my black GTS-t Type M for $6k back in the day, was immaculate and stock. R.I.P.
Don’t pretend like you don’t have the spare parts!
most safety and comfort features any new driver should have are standard kit on 2010 vintage euro at that price point, but most asian cars you’d struggle
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
