Hello!
I want to correct the roll center on my 1998 ER34.
When looking online, all I can find is roll center corrected parts for GT-R only.
I know extended ball joints are a thing, would this work?
The problem here is, I can find them for the front side only.
Also, I know there are adjustable lower control arms available that correct the roll center but they are a bit expensive and also only for the front side I believe?
Can someone help me please? I can't be the only one that wants/has corrected roll center on a non-gtr R34.
Thanks
Thanks for your reply.
I cannot access the car right now to measure unfortunately. But my guess is that it dropped 5-8 cm from stock. I want to correct the roll center because I think even the slightest correction will help making the car handle better, since I want to do more track events with the car.
If not please correct me.
Suspension wise it's got coilovers, hicas delete, adjustable camber arms, adjustable pillowball tension rods, tension rod bar, sway bars, drop links, roll center corrected tie rod ends. Aero is still untouched.
My intention is to build a good handling track inspired street car. Not too much power, just really good and precise handling. So yes, it is street driven but I will do the occasional trackday.
OK, so, the question again. "What leads you to want to correct roll centre on your car?"
Have you drawn a diagram that shows that it (the roll centre) is currently too low? You do know that this is not a crappy Mac strut car and that you generally have to lower the car excessively to cause this problem, right?
If you are sure you have a problem, what you need to do is cut and reweld the inner arm mounts (upper and lower) on the subframe to be higher by the desired amount (eg 10 or 20mm, or adjustable). I guess there would be weld on kits these days or you could do it custom.
If you are running the car low enough to have a roll centre problem on a street/track car, you are running the car way too low for practical use. I guess it could be a problem if you have a dedicated superlap car or similar
Best place to start for handling is to post up your ride heights and alignment settings. The factory geometry is pretty reasonable for most use.
  • Like 2
Sounds good. As everyone else is saying, if you haven't created a roll centre problem for yourself (by over lowering the car) then I think you are imagining a problem that isn't really there.
Why do you think there is currently an issue with the cars roll centre?
Back to some more practical advice, you say you want a 'precise' handling car, to achieve this you delete all the rubber bushes and hard mount/rose joint everything. Strong chance you'll then hate the car on the road so I don't recommend you do this. You'll also be creating a tonne of extra work for yourself as the rose joints are high maintenance.
I'd say at this point your biggest win is going to be by putting some real tyres on the car.
I'm guessing you do open track days and don't race in a class that restricts your tyre size or compound. So grab yourself a second set of wheels, the widest you can fit under your current guards and pop on a set of serious tyres such as -
https://samotorsporttyres.com.au/product/hankook-ventus-z214/
or if you want to spend a bit more
https://samotorsporttyres.com.au/product/hankook-ventus-f200/
And if your Mr money bags, there are plenty of other manufacturers eg Michelin, Pirelli or Yokohama, who make slicks that would love for you to make a donation to them.
Your current setup on a real tyre will be much quicker round the track then whatever setup your imagining on a street tyre will ever be.
Plus you get to keep your nice handling street car/street tyre combo for daily duties.
  • Like 1
So if I understand your comments correctly, there is no need to correct the roll center. Thanks for letting me know. Also thank you for the extra tips!
as for my tyre setup, I already run as much tire as I can fit in the stock guards. Yokohama Advan A052. 馃槒
It's not my daily car so I run them on the street as well. Works perfectly good for me!
  • Like 2
Sounds like a pretty well setup car.
If you remember what it was like going from street tyres to A052, you've got about that much performance again to be gained from going from A052 to a race slick.
Edited by Murray_Calavera
Yes that's what I'm going for. I thought maybe correcting the roll center would make it even better, but I guess I was wrong.
That is crazy!
2 hours ago, GTSBoy said:
Keeping in mind that a full race slick really requires completely different spring rates to extract the best from them.
True, if you want to extract everything from the slick, the suspension needs to be setup with that in mind.
However only changing the tyres and nothing else, the slicks offer another crazy step up in performance.
This is a nice video showing that -
Funnily enough, the video shows exactly what I said above. The step from street to R comp is the same again going from R comp to slick.
16 hours ago, blind_elk said:
What size?
F:235 R:255
I had R888R before in F:245 R:265. I kid you not, the Advans are wider than the Toyos. I think a 275 R888R would be about the same width as a 255 A052...
5 hours ago, r34.bryan said:
F:235 R:255
Diameter? Aspect Ratio?
Actually, I don't think this question has been answered. What exactly is the car doing - handling-wise - that makes you think it needs any adjustments to the suspension setup?
Okay so first off I don't have a lot of experience driving a lot of different cars fast. My car handles great, there is nothing weird going on handling wise (maybe a bit of bump steer). All I'm trying to do is make it handle as good as it could. The problem is I don't have anything to compare it to. So since my experience is lacking I'm reading online about other peoples (track)builds. And so my thought was "oh when you lower a car the roll center is off, so it needs to be corrected in order to make it handle better." Then I saw the kits are only available for R32-33-34 GT-R. Confirming these cars might need it. Hence my question how to correct it on a non-gtr Skyline.
Perhaps my question should've been: Does my car need a roll center correction to make it handle better?
Or: How to make an ER34 coupe faster around the track? (handling wise)
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 馃檪  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
