Looks like you've got most of the bases covered, one mod I've done to date (dare say it's the best handling mod I've done) was to shift the subframe up closer to the chassis.
This allows the arms in the rear end to sit more like how Nissan intended.
My LCA now actually slightly point downwards, where as before they were parallel to the road surface.
Overall gains so far, much more traction, no need to run 4mm total toe in anymore.
  • Like 1
  • Thanks 1
24 minutes ago, Murray_Calavera said:
These ones, they're a little more forgiving than alloy.
https://au.gktech.com/polyurethane-rear-subframe-bushes
  • Like 1
I'm not sure if you mentioned, but a good mechanical limited slip diff will make a big difference in a 2wd r chassis.
Also, it would be worth posting up you ride height (centre of wheel to guard) front and rear and also your alignment, plus any specific issue you have noticed (turn in understeer, mid corner understeer, corner exit oversteer, instability in a straight line etc etc)
  • Like 1
100% agree with this. A proper diff would be at the top of my list of priority mods.
  • Like 1
Wow didn't know this was a thing... perhaps this could be my solution! Since I wanted to renew all bushings anyways. I will take a better look at this mod. Thanks a lot @Dose Pipe Sutututu !
Good that you mention it, I'm currently saving up for one. After doing my research I think I will get the Nismo GT LSD Pro 1.5 way.
Since I can't access my car right now I will measure it once I get the opportunity + alignment settings. Corner exit is not really stable, my guess is maybe the LSD will fix that.
  • Like 2
Dumb question
Are these just pineapples by a different name (intended function).
Sell them to me. Axle tramp and my R34 are an iconic combo.
56 minutes ago, Kinkstaah said:
Dumb question
Not at all, pineapples are garbage as you move the subframe even further away from the chassis.
These are replacement subframe bushes
Good choice, don't be like me and get a KAAZ 2 way lol..
It's so aggressive, I had to get diff place to reduce the initial clamp.
My friends with Nismo diffs in their Silvias behave so much better.
  • Like 1
Depends on how you set them up!
(though most people do it for max squat, which is as you have described).
Something to consider next time the subframe is out, which realistically is hopefully fkin never...
Yeah pineapples are a simpler and more adjustable solution than changing the subframe bushes which is a big, subframe out job.
Pineapples let you change the angle of the subframe to improve (or worsen if you are a hectic drifter) the rear traction.
Replacement subframe bushes might or might not have the same geometry as standard, or might also change the angle as pineapples can, it is worth checking before installing.
Raising the subframe is a good way to lower the car without wrecking the roll centre geometry (back to OP's question) but space there is very tight depending on the chassis and setup (eg ATTESSA pump on top)
  • Like 1
DOOOOOOO IT..
I took mine out (again) and this time welded up the cnut with the GKtech brace kit and powder coated it.
I regret spending money on it, however the car does handle and hook up much better. In other news, out for more testing at Eastern Creek GP Circuit, aiming 1m50s this time round (will be 2nd time out on that circuit).
Is there also a kit that does the same but on the front subframe? Or did you only do the rear end?
Also, taking out the subframe(s) sounds like a good opportunity to get some Spoon rigid collars, I do need to do some more research on them tho.
I only did the rear as that was the area that gave me the most grief on the track, probably doesn't help I have a fair whack of power only out of two wheels.
Front end wise, I don't really have an issue with poor turn in, once again my car isn't that low so the control arms are ever so slightly pointed downward thus the tie rods aren't in a funny position to cause bump steer.
I do run 7° of castor, I wanted to run a bit more but already the tyres are a bit too close to the guards on lock (running 265/35/18 all round).
  • Like 1
Is the front subframe even mounted with bushings? can anyone confirm it?
I can't even find normal bushings to replace the oem ones. (if there are any)
No. So changing the height of the front subframe is a nonsense. And anyway, the only way that it is ever changed in practice is to space the front subframe down, to allow more room under the bonnet for taller engines (ie, RB30 blocks in R32s). This is the opposite of what's being talked about here.
  • Like 1
Yes, this is why at the front extended ball joints are the best option available for addressing bump steer, but again you just wreck the handling if you go too low anyway
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
