Hello,
I'm looking to make my own resistor ballast delete however I'm not able to find the connector... (and don't want to cut original hairness or from the dropping resistor)
I already looked into furukawa and yasaki catalog
If I'm not able to find it I will buy the one made by some company
Best regards
I don't know either, I have swapped mine to a Deutsch DT8 connector as I had a spare which came with no connector on it. It is a pretty simple connection with 1 input and 6 outputs which are interchangeable
4 minutes ago, bigboss59400 said:
Hello,
Best regards
https://www.wiringspecialties.com/rb26-injector-resistor-bypass/
Not sure of the exact connector source but Wiring Specialties has figured it out so it's definitely not impossible. If you do figure it out let us know, I'm curious to know where to get this stuff without paying hilarious amounts for individual plugs.
thanks for your reply guys
well I have the same mindset as @joshuaho96 I don't like to buy overpriced connector
yes I know it's possible but I already try everything I could think off
so except if someone can give us the part number and brand or give some other japanese connector brand to look into
I will go with the wiring spec or nzefi
How much of a tight arse are you guys !
The connector is available from EFI hardware if you really wanna do it yourself for about $25au and NZ EFI already done is about $45nz, so it's hardly breaking the bank.
  • Like 2
  • Haha 1
The connector is available from EFI hardware if you really wanna do it yourself for about $25au and Nz already done is about $45nz, so it's hardly breaking the bank.
Plus their connector is sexy! Well worth paying for.
  • Like 1
  • Haha 1
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
