1 hour ago, Dose Pipe Sutututu said:
@Murray_Calavera
It's a V35 Skyline pedal, ie same as the 350Z without the alloy pedal. I did have a 350Z one but wanted one with a rubber pedal.
Where'd you find one of these pedals I can only find the metal foot with a massive top covered bracket area?
55 minutes ago, Dose Pipe Sutututu said:
Whoops, meant to say G35.
This might be easy for you to access in your part of the globe.
https://conceptzperformance.com/items.php?p=214
Haha I'll look up g35 ones cheers man I'm in NSW btw my bad🤣
Some reason I thought you were one of those Muricannnnnn (inserts word not 2023 appropriate).
  • Haha 1
Hahaha Na mate True blue!
Did you make your own harness for that vq35 pedal to throttle and what ECU did you run it to? I was reading over the haltech DBW diagram last night I have a pnp elite 2500 in the 34. They say to signal ground any linked grounds near the ECU so individuals signal grounds run from each throttle and pedal back to the ECU then you just splice them in before pinning into the plug right?
Yes I did, in hindsight, I should have just bought a fast, modern car like a M2 or 3 instead of modding this shit box.
I ran a new patch harness from pedal to ECU. The power and sensor ground goes from the ECU to the pedal, then it is spliced from there to DBW TB.
If you hop on IG, I have photos of my shit box, @nhbautomotive
That's one tidy boat! :P
Had a few 33's back in the day yours looks like it rips I think it's definitely far opposite of shit box haha
It's slow for today's standards, does ok around the circuit compared to most boats lol
I would sell this shitbox in a heart beat if someone offered the right money. Will straight away go buy a M3 and let everyone on this forum make fun of it lololol.
  • Haha 1
What could potentially be done to bring it up to today's standards and do you just not like the chassis or the heart?
Hey hey hey can't talk about that euro stuff in here! :P
I was looking over that forum posted earlier from the fella that did the DBW on the factory plenum and noticed how he didn't delete the idle air control and cold start valve?? Also why didnt they mount the DBW throttle straight to the plenum and invert it or can they only be orientated that way. It stopped him using his tower brace 🤔
Edited by SandyBill
Would need a big list like adaptive cruise, lane assist, DCT or ZF, keyless start/lock/entry, adaptive suspension, better sound deadening, more airbags, better ABS system, traction strategy, etc. I'm pretty much describing a M2 or 3 or 4 lol.
Probably due to cost, I believe he just paid a shop. If I were to approach that, I would take off the top plenum and get the flange welded on and then get all the crappy OEM leak valves, emissions crap shaved off.
  • 9 months later...
Ended up completely forgetting to keep tabs on what's been happening so 10 months down the track and with much guidance thanks to Dose Pipe the semi finished dbw build ended with 300rwkw flex tuned on E85.
Here's some photo spamming.
Changed seals and gaskets as I went here and there. Bypassed the heater core for the moment until I pull the motor and aircon to do new heater lines and core fittings.
Replaced spigot bush and added a NPC pull button clutch.
Sorry for the wack order of photos...
Got some powder coating done and ceramic coating on the manifold and turbine housing for the Hypergear High flowed stock turbo.
After some mucking around and a message to haltech managed to chase down and fix an issue where the dbw wasn't receiving enough voltage.
  • Like 1
Hypertune 100mm thick cast end tank cooler welded up and sat right at home.
DBW flange welded to the Rajab upper half plenum then plumbing through under the battery tray.
45mm external gate fitted up and plumbed back into the down pipe.
  • Like 3
Got her home safely.
Just have a few more things to fiddle around with and change but I'm very very happy with the end result and I'd like to thank
Dose Pipe (NHB automotive) for taking so much of his not existent spare time to talk me through so much shit I honestly owe this man my car.
MK raceworks (Matt) Extremely talented, cool, kind bloke did above and beyond with all the fab work and resolved all and any issues without a break of sweat.
DVS Tuning (Jez) For being patient with me for 7 years endlessly talking about getting the car there eventually and then having the patience to fit me in last minute you sir are a legend.
Edited by SandyBill
  • Like 6
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
