Amazing. You’ve done basically everything I want to do, besides missing the longer drive for the oil pump (did you have that already?) and an oil drain at the back of the head. Manifold looks so good plus it all looks pretty tidy.
I noticed you also had a coolant leak at the connector for the heater core hose above the starter. Interesting, I just re-sealed that connector a couple weeks ago.
Thanks man na haven't opened the engine at all yet that will be happening in the future one day, along with the head drain.
It wasn't leaking I just slowly removed all the heater gear and found all those old tin fittings did t have much life left in them anyways so deleted and bypassed the heater core for one day when I pull the motor I'll pull the aircon and do all the lines and core fittings properly with boost docs kit 👌
  • 3 weeks later...
Hello All,
Came across this post on google and thought I'd share some of our product offerings incase anyone find this and is looking for a more plug 'n play solution. Yes, we are a US based company and we specialize in making modern tech upgrades to these older cars easy. We do also have a couple Aussie distributors incase shipping is an issue.
We recently released our adapter for the OEM RB25 manifolds here: https://outsidergarage.com/products/nissan-rb25-oem-dbw-conversion-kit?_pos=3&_sid=fffd4893b&_ss=r . This is designed to keep things as short and clean as possible.
We also offer MANY other bolt-on adapters for common aftermarket manifolds, plug & play harnesses, and IACV block-offs - no need to cut and weld anything. https://outsidergarage.com/collections/drive-by-wire/Drive-By-Wire-(DBW)
Stay tuned to our site as we have a number of new DBW products hitting the website in the coming months.
- Steve
  • 1 month later...
On 21/11/2023 at 7:50 PM, outsidergarage said:
Hello All,
- Steve
What ECU's are able to control these??
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
