Hello all,
Been a long time since I’ve been on here but hoping you guys could provide some information.
i searched here and the internet to see how to identify a R32 rb26dett by series 1/ series 2 engine but no luck. Maybe because these engines are so common now worldwide? Somewhere online long ago I read you can tell cosmetically and based on the engine serial number?
How do I identify a early 1990 rb26dett vs a 92 vs R33 rb26dett.
Is there a recommendation on where I could check the serial number to identify the engine year range?
thank you all for the information.
Edited by Norcal510
https://www.sau.com.au/forums/topic/484376-rb26dett-engine-differences/
I've never seen a reliable cross reference between year/vin#/engine number.
early 32 and late 32/33 engines are pretty much identical, especially by now when they all need a rebuild anyway. The only meaningful difference I can think of is the longer drive on the crank for the oil pump, but they are easily replaced if you have a short nose one
9 hours ago, Norcal510 said:
Hello all,
The main way to tell between an R33 RB26 and an early R32 RB26 is going to be minor stuff. The main difference will be the crankshaft which isn't visible without removing the oil pump. There's also differences in the knock sensor harness, but the actual knock sensors should interchange even if the factory knock sensor was not the same. Heater core hoses are different as well. For example the back of the block has a coolant pipe that is 05U07 for the R32 but 24U00 for the R33. The pipe that goes between the back and front of the block for the heater core and oil cooler is 05U15 for the R32 but 24U00 for the R33. The R32 also has a sensor (?) of some kind on the firewall in the heater core lines.
Probably the easiest way for the untrained eye is to just look at the block serial number. It won't tell you exactly but it's close enough.
Most of the stuff mentioned here are not really engine differences, but car model changes with things that bolt to the engine. To me the only differences between actual 05U RB26 engines I can think of are the crank oil drive lengths between early and late R32 and the exhaust camshaft change from R33 to R34. Everything elae is an ancillary change fitted to the long engine for the car that it's installed into.
  • Like 1
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
