  On 23/01/2023 at 11:24 PM, GTSBoy said:
Yeah nah. Flex fuel sensor should be put in the low pressure return line. No need to punish it with several bar of static P.
P sensor in the rail feed line is sensible. But the obvious answer here is to buy an adapter to put an aftermarket pressure reg on the tail of the fuel rail and use the gauge port on the reg to mount teh P sensor.
Expand
I'm not a fan of putting it on the return side, you have issues when say there's not enough fuel flow, god forbid air pockets,  and your ethanol sensor isn't sampling correctly. This could happen say during a high G event.
Sure you can set sampling thresholds such as you need x bar of fuel pressure, y RPM however better practice to have it on the feed side.
OEM cars run deadhead systems with the flex sensor on them without issue, also those Continental flex sensors will happily take nearly 10 bar of fuel pressure.
FWIW (also subjective) I run mine on the feed between the main tank and surge tank.
Expand
All true. I just follow the policy of fewer high pressure hose connections is better high pressure hose connections.
Also, there will always be fuel in the return, and it will get refreshed often enough. You'd have to be on full noise, maxing out the pump capacity such that there is no return flow, continuously, while a substantial change in fuel ethanol content arrived at the engine, for your concerns to be realised as engine damage. Any little burp of the fuel reg to release some fuel will always put some fresh stuff past the sensor.
  • Like 2
Is anything going to happen if the flex sensor isn't sampling fuel for a period of time?
I mean the e content of the fuel is the e content, after a few minutes of driving, the mixture never changes.
I could only ever see this being an issue after filling up the tank and before the current mixture was established.
Is there something I'm missing?
Expand
  • Timing drops - loss of power
  • Lean out - misfires and/or engine protection triggers
  • Shit lap time.
lol
  • Shit lap time.
lol
Expand
But it won't happen realistically. Even if the sensor starves it has little to no effect as the sensor is so saturated it takes minutes to register any sort of dramtic change, and that's before even talking about the sampling threshold settings.
  • Like 1
Expand
True, but at SAU we like to over think things for no reason :D
  • Shit lap time.
lol
Expand
Ah ok.
I was thinking that if the sensor was starved of fuel, it would not send a value to the ECU. So the ECU would just keep using the last known value.
But what you are saying is, if the sensor was for example, just plugged in to the ECU with no fuel flowing through it at all, it would still function as expected and send a value to the ECU for 0% ethanol?
  On 25/01/2023 at 5:37 AM, Murray_Calavera said:
Ah ok.
Expand
To be honest I do not know the answer, however there have been discussions about this on Facebook's Haltech group not long ago.
Here's a few responses from people much smarter than me.
Turn your car on and don't start it for an hour - the ethanol content won't change from the last time it registered fuel flowing through it. It doesn't just return to 0%
  • Like 1
  On 25/01/2023 at 9:49 AM, Duncan said:
surely......if your ethanol % drops from say 80% to 0%, the ECU pulls timing like it was straight 98....so fails safe
Expand
Except for the leaning out part......
  On 25/01/2023 at 9:10 AM, GTSBoy said:
That's probably because the same fuel is still sitting there in the sensor, getting sensed.
Expand
Not really. The Haltech remembers what fuel was there and assumes the same fuel is still present even after a significant amount of time unitl the sensor reports something else dramatically different. Even then, it will slowly decrease the % sensed, not drop off a cliff.
Expand
This is a situation this can never really ever happen. Even small traces of E85 will not let it drop to 0 instantly - you might see a 20 - 30% drop when 98 is first sensed. When I had about 5 litres of 98 and then dumped 40 litres on top of it with E85 it took about 30mins of engine running for the sensor to stabilise at about 70% watching it on the canbus gauge and pc, doing 1% incremental increases every 30 seconds or so with the Haltech flex sensor.
  On 24/01/2023 at 11:12 PM, joshuaho96 said:
Expand
  On 24/01/2023 at 10:54 PM, Ben C34 said:
Expand
Expand
Thanks for all your lovely answers. im little confused still about this sensor. the oem fpr is enough to deal with from what i know and i want to replace as few things as possible. The police is very picky also, they literally tried to bring mates car dowm by claiming there isnt the oem brake fluid or something stupid.
But i also want a relaible car. Idk if my Old link G4 ecu can read fuel pressure.
If it can, i guess i plug it to the ecu? By a 'T" connection into the fuel pressure side between filter and rail?
if i cant i guess i place a gauge in the flightdeck so i can keep an eye on the fuel pressure?
are these cars so sensitive? i mean, an old volvo, opel or whatever can run dry on fuel, run forever with no oil change or run jet diesel without issues. Can drive forever with broken lambda sensor etc haha!
How do you do with the lambdasensor? from factory there is 2, right behind each turbo. Do i plug these and place my new one further down where the 2 elbows connect to 1? and only use one input/connector? Usually they say that you shouldnt put the sensor so close to the turbos.
i bought a lambdasensor AEM kit including controller. There is only one lambda sensor in here.
1 sensor or 2? can i even run 2 with the AEM controller kit.  Is it better to rum 2 lambdasensor on each elbow?
Expand
The Link G4 can read the fuel pressure sensor provided you have the spare input for it. Yep, you can T in between the rail and fuel filter for the sensor.
For your wideband O2 sensor, one sensor is fine and you can install it in front of the cat. You'll need to get a bug welded on for where you want to locate it. Where the factory O2 sensors are, you can leave the factory sensors there. I wouldn't install a wideband sensor so close to the turbos.
  • Thanks 1
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
