On 3/22/2023 at 5:54 AM, PonieBoi said:
Rears can tuck 17x9 +30 with stock arms (bought camber arms all round just in case)
20 hours ago, GoHashiriya said:
Looks really nice, good work
Except that it is clearly too low at the rear (and presumably at the front) and will handle like a bucket of puss. The suspension arcs are not supposed to work with the wheel pushed that far up into the well.
If you're going to run it that low then you really should be using different bushes to push the rear subframe up towards the floorpan as far as it will go, and drop spindles. Drop spindles at both ends. The GKTech ones are good, and you will need/want to use their upper and lower arms with them also.
Edited by GTSBoy
Coilovers are how they came out of the box. Only just got the car home today.
Got camber arms for front and back but don't really need them.
Got the car home for the first time in nearly 6 months.
Fresh kit, paint job and wheels.
Next on the list is chucking in a non hicas subframe which I'm in the middle of doing the gktech reenforcement plates on, and also will be looking at new injectors and one of mine has a leak.
  • Like 2
Now that I can go back to working on this thing. Back to trouble shooting.
One of my problems is the car doesn't like to start again after it's hot (hot start). I have to disconnect the fuel pump to starve the motor, reconnect and start.
Got the injectors tested and cleaned, pretty much all above board. Will wack them back in, take the car around to Jaustech (SA), get the hot start config looked at.
What GTSBoy was mentioning has nothing to do with if they fit or not while stationary.
At super low ride heights, the top and bottom arms, along with the tie rods, move into some very odd areas, where as the wheel travels up and down, it will actually start to turn left and right.
Low ride heights, end up with bump steer.
Perfectly fine if you have a show car, but if you want to actually be able to drive down the road and have the car NOT automatically turn left and right unpredictably (with no steering wheel input) then super low height won't work. Camber isn't the only thing you need to worry about...
I know what he meant haha. I've raised the car since then but the moment I got them out the box without adjusting them, that's how they sat.
  • Like 1
  • 1 month later...
Been a minute. Haven't really done much with the car. Just enjoying it.
Pretty much finished my non-hicas subframe.
Figured I'd re-enforce the tabs and mounts before it gets painted.
It's not pretty but for my first time welding, itll do alright haha.
dzvHClmW1EIEbTmayOdmR3dhNmQgbiJgETJkwb6a9lHkPhNIfT_Le6XklAvLcA1Dgah6yAXiyYp56vM6nhmd7wqnGCDX8UO-QXExDGh-T7YBuNUSudVh5x95_ZT9GQR1k1bqRMeyxp-XBhzKlI2gOw1iB7F6tkeZFCrUTniztHB7sF2-Zy31MjgJlL8floVZva_bD43qB4AAQZe3LopSrhFda6fwUW9rNF_CW7FYlvfZNFQ6B3iJfEJAx5zxpQq4kpY5rYJOMS8VvHDMmCEGVXaUFyqLkNpQ6nMM-xCnTULhIShIRJS5IFVkiiRqEkO_5f1ZXzftFGaNf223ATn6bRaIaJFey5LIhoJzZ5V5vnxzFhpZbFXt_p4mMQpdfD4N41tJDgiQqOl3hvKX_RUTemRqpSnl3zBxeMVrqeKAo7zGkkJa_EnVWMNbuAveq0_bl3n0GgldyPRyKRpwnSKPYlKQ5Zibr29njHfL6jTVnJbQivXm05G0EIBV1OJxRdS4lWUOzWMNpr-5p8iK1e_k52aQ6xGonPxpO8D_hiOvQG1Npv3Y-s9p2VVFl8a73LTKIEoTik5hgDpddS3KxDV2A8CoDVSYXWhTCGRD1hO30WmpFzc3-PQyI9igOIQZcxkLmIKkVPSvATLrBRusoc-YrJumY4l_DeeDIyeo8pszwTbt6nhRQEeg72yFJ8cZnzivTPWkT_lECkfzo-VvntwP0EK1ZyqPxwuS3PTlczbqizEVsXtspMarCb1Arg6J0JULaKmtvVhE0UhaHOeuzSJxphWrFHudYt1Cmnew9kNzypnFGhQ_xIxD1B7GL7l1w3KN46Ne6oqvA7Tj5t8ejlNluGWBfdueaE1rj9lcfTwk6CGaICc1YnHlNHZgiZKOVyG4ZcXH6xPhRSYU8cnX4Aqkryq5nBiP-8wVMGdIkTTNK-SmuxnOGQ=w1328-h1000-s-no?authuser=0
Pulled my knob too hard (haha) and shifter bushing became non existent. Went to get a gktech solid bushing from Sleekas and it turns out the bushing has worn that much, I need to get a new/not f**ked shifter.
If anyone has other aftermarket options they have used, hmu.
Turns out there are 2 different sized shifter balls, and therefore 2 different size shifter bushes - noting they might both have the same outer diameter where they go into the gearbox
Looks like R32 sedan is the smaller shifter ball
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
