Here is a short Tutorial How to replace the Engine Mounts by lowering the front axle Member.
After 20-30 years it is always a good Idea to replace them , even if you vibrations or a buzzing noise.
Also Replace the Mounting of the Gearbox and the Proppelershaft!
I couldn`t find anything about this so here I explain how I have done it.
First you have to jack the car and fix the Engine from moving around, this is important cause you get int trouble later when the scrwholes not aligne .
20220921_143433.thumb.jpg.30b35f7a3a0e68dafdb86a7ffa995d83.jpg20220921_143429.thumb.jpg.00e65efa9e53fab6fe78fa88f73ba31b.jpg
Then you hang the engine at the Engine Bay. I have a special Bracket but a Tube and a Strapband will work also. I made myself a link which is screwd at the Engineblock
20220921_143410.thumb.jpg.781f78ece14ae8887fb3e8b44107bf72.jpg20220921_143414.thumb.jpg.ef87e7900a23306725b5f949bd410ebc.jpg
After everything is prepared you can start to remove all the nuts.
Start with the 4 nuts of the Powersteering and the clamps of the oil lines. There is a clamp on the left side over the cv shaft which is a little bit hidden the otherers are easy to locate.
Double check everything is slack, you don't want to bend the lines!
The next step is the trickiest part.
Loose the nuts of the Engine Mounts, 3 of them are easy to reach but the one under Turbo is hard to loose cause there is not much room.
After I tried all my 14mm wrenches, and I have a lot, i figured out this solution.
This a 14mm Gearwrench ratchet with a  extendeble double Tube.
The wrench has to be flat without an angle and it should be really long cause the nut is really thight.
With this tool you can get there from the gearbox side and you should be able to remove it.
Before you loose the Axle Member check the aligne holes between the bolts!
Do they match? Take a photo. Mine had a little offset
.20220921_143424.thumb.jpg.db268301fb589cd9c8f98d6085c46574.jpg20220921_143451.thumb.jpg.4b164b54212e15cabb97a5f2ee41cff3.jpg
Loose the Nuts to the end of the Bolt, do NOT remove them completly.
Then carefuly lower the jack , stop and check if everything is loose and the member ore the line are not bend or stuck.
Remove the nuts on the right side and lower the Jack until you can get the Rubbermount out.
Replace it with the new one , lift the jack , insert the nuts. Do NOT thight them .
Same on the other side.
20220921_145024.thumb.jpg.e3554f744db0f2a909aa4fc9b230878c.jpgIMG-20220921-WA0004.thumb.jpeg.b73b58ec869482159221910c7ec94457.jpeg
Compared to the new the olds are 2mm lower and on the Turbo side they hafe some cracks.
Tighten the Nuts of the Axlemember , then the Steeringrack and the Oillines.
Here are the Tightingtorque specs. Tighten the Steeringrack the right way! First the upper Bolts then the lower ones .
20220922_115522.thumb.jpg.d5a050c69cee2fe274e842c3fb9c473a.jpg20220922_115636.thumb.jpg.6fad0270b4c8b69917f8b28c0dd38bac.jpg20220922_115902.thumb.jpg.543dd5689787bb3406642718eb4e7a77.jpg20220922_115955.thumb.jpg.fc3f8daf5923d3d0e16c77bb9d4d71f8.jpg
This are the required Tools
Took me 5 hours total including making the hook and wrench extension, all this is not too complicated, but it's better if you've done similar things before.
Possible this is helpfull to someone.
  • Like 6
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
