Is it bad when you haven't driven your Skyline for so long that . . . .
11 hours ago, r32-25t said:
I will never let mine end up unregistered
Can you keep it registered if it doesn't run? Or do you have a hard deadline to get it running again before the pink slip is due?
It hasn’t run for over 2yrs now and I’ve kept it registered the whole time just because I don’t want to go through the drama of trying to get a blue slip
my hard deadline is all Japan day
  • Like 3
On 02/02/2023 at 2:47 PM, Dose Pipe Sutututu said:
Need mmoaaaarrr M3 Eurotrash as everyone here calls it.
You'd get rolled for sure.
Having an Asian car, they think you're part of 5T or something :P
LOL... show them my non-existent dragon tatt on my back and my non-existent tiger tatt ono my chest..
dumaaaaaa
  • Haha 1
nah, they all drive mercs, BMW or Audi's....it's a status thing!
  • Haha 2
Oh those hoses under the manifold are spectacular to change !
Changed out the heater hoses on the drivers side thinking they were cactus . . but its still leaking.
Made up a bass T piece with hose barbs and soldered in a car valve extension, plumbed it into the throttle body coolant line, filled up the cooling system, put on a tyre compressor and pressurised it and . . . . found the leak !
Its the short 2 inch piece of hose that comes out of the block . . . . above the started motor . . . . so you cant get to it from above . . . soooooo . . . its out with the started motor . . . again . . . . to access it from underneath . . . . went and got a piece of 19mm ID hose that will take about 20 billion pounds of pressure cause I aint doing this again
Hahahaha. I'm sorry for laughing but exact same thing happened to mine about 6 months ago what a prick of a job that was. I wish you all the best. :1_grinning:
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
