Is it bad when you haven't driven your Skyline for so long that . . . .
11 hours ago, r32-25t said:
I will never let mine end up unregistered
Can you keep it registered if it doesn't run? Or do you have a hard deadline to get it running again before the pink slip is due?
It hasn鈥檛 run for over 2yrs now and I鈥檝e kept it registered the whole time just because I don鈥檛 want to go through the drama of trying to get a blue slip
my hard deadline is all Japan day
  • Like 3
On 02/02/2023 at 2:47 PM, Dose Pipe Sutututu said:
Need mmoaaaarrr M3 Eurotrash as everyone here calls it.
You'd get rolled for sure.
Having an Asian car, they think you're part of 5T or something :P
LOL... show them my non-existent dragon tatt on my back and my non-existent tiger tatt ono my chest..
dumaaaaaa
  • Haha 1
nah, they all drive mercs, BMW or Audi's....it's a status thing!
  • Haha 2
Oh those hoses under the manifold are spectacular to change !
Changed out the heater hoses on the drivers side thinking they were cactus . . but its still leaking.
Made up a bass T piece with hose barbs and soldered in a car valve extension, plumbed it into the throttle body coolant line, filled up the cooling system, put on a tyre compressor and pressurised it and . . . . found the leak !
Its the short 2 inch piece of hose that comes out of the block . . . . above the started motor . . . . so you cant get to it from above . . . soooooo . . . its out with the started motor . . . again . . . . to access it from underneath . . . . went and got a piece of 19mm ID hose that will take about 20 billion pounds of pressure cause I aint doing this again
Hahahaha. I'm sorry for laughing but exact same thing happened to mine about 6 months ago what a prick of a job that was. I wish you all the best. :1_grinning:
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
