Hi Guys
Has anyone come across this problem with the aircon air flow slowing down to almost no air coming out of the vents after the aircon has been running for about an hour? The air flow will return if you turn off the AC for maybe 15-20 minutes If you run the AC again, the air flow will slow down again after a few minutes.
Cheers.
8 hours ago, believer said:
Hi Guys
Cheers.
If it isn't the fan speed going down your evaporator core is almost certainly freezing over. Get the system evacuated and checked for leaks, then verify the compressor is working correctly.
If it's freezing the evap core over, then it's not a leak/gassing problem, or a compressor problem. It would be a TX valve problem, not cycling the compressor off when the core gets cold enough. So either the TX valve stuck or the temp sensor come off the core.
I've had a new car with evap core freezing issues, seemingly related to low refrigerant charge. So not impossible but worth checking.
4 hours ago, believer said:
How hard is it to get to the TX valve and the temperature sensor on the core?
Dunno on a 33. The core is buried under the dash on any car and is no fun to get to. The TX valve could be also, or could be on/near the firewall behind the turbos.
It's a job for a fridgy anyway.
Edited by GTSBoy
On 08/02/2023 at 1:40 PM, believer said:
Thanks for all the replies.
Super easy! You will need to get the ac degassed before you attempt to remove it. Remove the glovebox, then you can get access to the heater box and undo the 2 ac lines that poke out from the firewall near the turbo. I'm sure there are many detailed threads on this already.
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
