Good afternoon,
I've got a leak out of one of the half-shafts and need to replace the seal.
I've searched for a guide/another thread, nut can't seem to find one (happy to be corrected)
What is the method for removing/reinstalling the half shaft after replacing the seal.
Cheers
https://www.sau.com.au/forums/topic/484428-removing-half-shaft-from-diff-r33/
4 hours ago, Pattey21 said:
Good afternoon,
Cheers
When I had to do this for the front diff I removed the diff cover and spun the diff until I could see the axle inside the diff. Then I used a plastic pry tool with a simple flat edge that gradually widens to full width and a hammer. Jam the pry tool in and use a hammer until the axle pops out. As far as I can tell it did not mar or bend any other parts of the diff this way. My least favorite thing is scraping/prying something out with metal on metal so this was a foolproof technique for me and the car needed a diff oil change pretty badly anyways. Then I used a slide hammer with an expanding jaw puller to remove the seal itself. Be careful when you do this because it will suck to damage the seat of the seal. I expanded it into the rubber to keep it from marring the seat instead of trying to catch the back edge where it meets the seat.
Another method I've seen since doing that job was a tool that hooks onto the outside of the axle and makes it possible to slide hammer the axle out instead of trying to use a pry bar.
  • 3 weeks later...
So i refilled it and layed it on its side for a day (new seal side down) no leak, went for a drive today and its weeping. Is it possible to be weeping from the half shaft seal, do the take time to bed in?
The seal cam pre-greased in the centre and i lubricated the shaft prior to install.
7 hours ago, Pattey21 said:
I didn't inspect it thoroughly but my impression when cleaning it prior to lubrication, was the it was "serviceable" but my focus was more on the seal itself.
Not 100% across this half shaft in particular as I haven't removed one, but it will be pretty much the same as others...
The surface the seal rests on on the half shaft itself can also wear. If it starts to wear down, it's not going to mate and seal properly.
When doing the seal, you need to be checking the inner and outer surfaces it mates to, are in good condition too.
Is the oil weep 100% coming from the half shaft seal location?
Have you checked the breathers/vents aren't blocked?
Blocked vents will bust an axle seal/make them weep. This could be why it only showed after a drive, as it needed to heat up and pressurise first (diff unable to breath)
Hectic few weeks at work.
I made sure to clear/check the diff vent but I will check the breather hose.
My guess for it being the half shaft seal location is based on filling it prior and lying it on the damaged side overnight and it did not weep.
ill have another look underneath/ check the breather hose
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
