1 hour ago, GTSBoy said:
Just don't run one. Convert to pencil coilpacks with the igniter built in. Many Toyota, Audi or later Nissan (VQ, VR) options exist.
Thanks, this is exactly the innovation I was looking for. Is there a "bolt on" pack for this swap or do I need to get into creative wiring?
Whether you need a programmable ECU will depend on whether the coils will be happy running the factory RB20 ECU dwell time. I think for yaris coils, Audi coils, Nissan pencil coils, etc, they're all fine running original dwell. I think the suppliers of these kits might be confusing themselves wrt the dwell question, because back when people used to use LS coils as an upgrade, they were definitely not happy with the factory RB20 dwell time.
But...."programmable ECU" is a triviality on an RB20. Just put a Nistune board in it. I cannot imagine running any Nissan ECU without Nistune in it. Why would you put up with all the factory stupidity, when you can get rid of the R&R, run more boost, make more power, make it cruise leaner and use less fuel, etc?
11 hours ago, R32RB20 said:
Thanks I've had a look at a few, there not cheap either. The only thing that's confusing is some sites say they need programmable ecu and others don't for the same product.
Yeah I'm in Oz, Sydney in fact
Check RB20 stock dwell time but RB26 coils have 2 ms dwell on the stock ECU and the R35 conversions work just fine without a tune at stock-ish power. Going to R35 coils is cheaper in the long run with how insanely expensive the ignitor is. I bought a replacement but most likely if the ignitor ever breaks again I'm going R35 coils.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
