My BMW 335i
PranK
 Share
On 24/06/2024 at 3:30 PM, PranK said:
I do have a tiny tiny misfire occasionally but I think it's because I got a little fuel down into a plug tube so I'll pull the coils out and see if I can dry those out.
I haven't done anything here, I'm assuming whatever liquid was in the tubes has just dried out with driving as its back to a beautifully smooth idle again. Might have been a little bit of water as some got into the bay when I was putting the new cover on. I was working in the driveway during some pretty wet weather which wasn't ideal.
  • Like 2
Ok, so the stupid new headlight is in default BMW "blind all the eyes" mode, pointing far too high. Screwing the adjustment screw did nothing, so I pulled the screw out (all the teeth on the plastic cog were broken) and I can just manually push the adjuster forward or backwards, which "fixed" it, but now I have no adaptive control. 😒
I might pull the adjuster screw out of the old headlight and see if replacing that will help.
3 hours ago, Kinkstaah said:
I dunno man it seems pretty much always like this.
I know, but I'm banking on just enjoying it soon once I've fixed things. I want to get some upgrades done soon rather than repairs.
I'm relying on my experience with the 330i that once you get to everything that previous owners neglected it can just be a reliable tracked street car.
Going to do rear wheel bearings and rear subframe poly bushes next.
I have Whiteline subframe inserts (they're supposed to take up the empty space in the bushings) but its still too soft. I did consider going solid aluminium subframe bushes but they can cause stress cracks in the body and the subframe so I'll just go with the black poly bushes instead. The car is super squirmy when giving it a bit.
 Share
    • I think the PDM outputs (the ones that can actually output big power) are not intended to be driven like that. They're either on or off, switched only at a low rate. To do PWM you need to use an ECU output that is PWM friendly (ie, able to be run at high frequency) and drive a separate SSR, instead of trying to thrash the (presumably) SSRs in the PDM.
    • +1 on the FPG fuel hat! funnily enough I tried to PWM control my fuel pump (Walbro/Ti Auto 450l/hr) through the PDM and it didn’t like it. Scott from Haltech said they don’t like it? So I just run mine at 100%.
    • Brand new SPARCO Jade Top Racing 3-Layer SFI 3.2A/5 race suit. Bought new and never used. Original tags attached, comes with original packaging. Brand: Sparco Colour: Black & White Fire rating: SFI 3.2A/5 Size: XL (see sizing reference chart) Price: $500 + postage Located eastern suburbs Melbourne. Will ship interstate at buyer's expense.
    • Mine looked exactly like this too. I found that if you didn't have them tightened to 100000 ft/lb, they must create some sort of arcing, and melt.
    • Great info. Dead right about the centre bearing being backwards. I put mine on wrong thinking the F in the rubber molding meant 'front' but it actually means back... You can also replace the boot. I bought a GKN high speed boot like this: https://en.oreca-store.com/gkn-cv-joint-boot-for-cv-joint-a-107-mm.html or https://www.race-parts.com/gkn-108mm-od-size-15-cv-tripode-joint-fast-boot I found my cv's were in good condition and i just washed them out and re-greased them with new boots.
