Autostrada Accessories supplied and installed their retrofit kit. you can purchase it from them however it does cost about $600. From memory the total install price i paid was $700-750. I found it worthwhile as i drove highway alot. From the email 5 years ago heres their part number Etc E-Cruise, Nissan Skyline V36 SKU # 101732 Part # EC-NI11NO
Thanks for that, I figured it would be problematic at best. What aftermarket CC did you go with? As I like the idea of it at least showing the light on the IC.
Used to build my rigs, but just doesn't interest me like it used to, so now I run a couple OE machines: HP 15s-eq Notebook 45W - Ryzen5 5500U - 2x8gb Corsair DDR4 3200 - 970 Evo Plus 1tb HP Elitedesk 705 G4 35W - Ryzen5 Pro 2400G - 2x8gb Kingston DDR4 2666 - Kingston A2000 1tb They're compact, low watt & game surprisingly well if you're not wanting more than 1080p.
Went down this road, Ended up not being entirely possible i purchaed the OEM Steering wheel buttons/shroud and had a place in brisbane install an aftermarket CC. They're able to utilise the steering wheel buttons for this 👍 The light also came up on the dash as the wiring for the control loom is there. As close to factory as you'd get.
Ive been digging pretty harshly on oil info tonight. Seems like you're mostly right, except they do have some info that in the higher temps (like SEQ), I should push more to SAE30, but otherwise, meh. Also, felt the oil, it doesn't feel very oily any more... It also had a light smell of fuel... As for starting, well, I've already abandoned the pull start, as it failed. Cord rotted, and metal throwout things rusted up and jammed. So now I use a battery drill and a socket... Electric start FTW! Also sharpened the blade while I was at it tonight. She was very dull... Mark, for blades, make your own. They're just mild steel. I made mine to be a high lift blade. It really throws the grass in the catcher. Might have been a little too high on the lift though... It was enough that it started to bend the blade tips down towards the earth... Ha ha ha I may have put some epic angle and size on my wings...
