Hi Guys, looking for some info on how the snow/snow switch works from the electrical side of things or some kind of manual that shows the transmission wiring etc (don't see anything in the workshop/engine manual).
Vehicle is a C34 Laurel, originally rb20e auto (3speed+OD). The switch used to always light up orange when switched to power mode.
I swapped the engine to a rb20det, ever since then the snow mode still works, but the power mode doesn't (at least 99% of the time but weirdly it did work the other day out of the blue for about 5min then stopped again).
Wiring wise:
- all of the wiring from the trans to the body/transmission computer are unchanged from factory.
- wiring FROM engine loom/ECU TO the trans control unit (related to throttle position) are hooked up
- wiring FROM trans control unit TO the engine ECU (which tell the ECU what gear it's in) are not connected as it's a manual ECU
Transmission operates and shifts fine - just the power mode doesn't seem to engage, assume something with the wiring but weird that it did actually work briefly the other day which got me wondering if there is some other variable at play.
Anybody out there have any ideas or know where to find a workshop manual for the transmission?
https://www.sau.com.au/forums/topic/484433-auto-trans-snowpower-switch/
It's just a digital input to the TCU. There's no secret magic. Break out the multimeter and start probing that input with the switch on and off and see if the circuit is connected properly. If it is reliably detectable (that you have turned the switch on) and the TCU doesn't activate power mode, then there is either a problem in the TCU or there is some other input that the TCU is not happy about.
If the only change you made was to the engine and ECU, then it is remotely possible that the ECU is not providing some signal that the TCU wants to see to be happy. This is more common with later ECU/TCU combos than early. They talk to each other on a data bus, not discrete signals.
The other possibility is that you have simply created a wiring problem when you pulled it all apart and put it back together. A broken wire or faulty multi-pin connector perhaps.
  • Like 1
Yes, very possible for it to be wiring problem or possibly even led in the switch....you need an answer to that first question about what that switch actually does to know if the trans is responding to it or not.
I understand that Snow should lock our first gear (ie, you move from a standing start in second) and Power should allow it to rev to redline before changing (while normal probably shifts at 70-80% revs) but I am not certain
  • Like 1
Thanks for the suggestions - will get out the multimeter and do some more digging, the way it briefly worked the other day makes me wonder if it is indeed just a broken/loose plug - or even could be just the LED not working - will have the car road legal soonish so will actually be able to test out properly if it changes anything by having the switch on/off.
When sorting out the wiring was going off of the wiring schematic for an r33 rb20e auto (in the engine/workshop manual) which I'm pretty sure is more or less an identical setup to c34 - there was no data bus between the ECU/TCU just some pretty basic inputs/outputs
- throttle position feeds into the TCU which when not hooked up made it shift at really high rpm even on light throttle - once connected works mint
- signals from TCU to ECU for what gear it's in - my understanding is this affects ignition timing on the auto ecu
Edited by 4rrow88
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
