It is factory manual(5 speed)
The lag is "most" noticeable on 4th gear but it can stil "lag" on 3rd or 2nd...but on the 2n/3rd it is really like "milisecond" loss of power but gas pedal reacts normally.
And it not do that all the time...the "loss of power" is only sometimes and the "i dont know what you want me to do" on 4th is happeing often like the just do not react to the gas pedal(it reacts i can feel/hear it but like nothing happens for a moment)
But as i said it i only a cruising problem and when i try to maintain the speed.
When i drive it "harder" the car behave as it should...
Edited by Kapr
You really need a diagnostic cable and logging of core ECU parameters to get to the bottom of this.
  • Thanks 1
In my experience the MAFs are pretty robust in these, mine is original and with 255k on it. I did re-sodler the joints at one point but that wasn't my issue, it was the CAS. I would even take a punt at getting a used original MAF from yahoo auction if mine was suspected of funny business - there's one right now at about EUR 50.
You said your coils were splitfire, but how old are they? They will fail just like the OEM ones and many have 100k+ kms on them now. I thought splitfire went out of business a while ago?
The parts GTSBoy mentioned earlier really shouldnt be too expensive. I went ahead and just threw those exact parts at the car for preventative maintenance - OEM coils/plugs/harness, soldered MAF, rebuilt CAS and Walbro - and, touch wood, it's running fine.
All this stuff won't be so expensive and you should really expect to replace them anyway on a 25yr old car.
  • Thanks 1
@joshuaho96 Do we need any "special" software? I know(99%) that the car has no OBDII port and that i have some extension cord to the interface to OBDII
@GoHashiriya
Can you send me the link? I do not see that(it is friday so maybe it was sold)
Yeah they were used but i dont know how many km they done but i presume that if some of the coils gone bad the car would run on 1/X cyl less same as the problem with the connector?
As for the parts...yeah coil are old splits...plugs and harness is brand new...MAF is OEM and upon inspection looks good...connector to that too. CAS i rly dont know(can it do that?)
For the info i have.
I took the car to the highway and the symptoms are that most noticeable "lack" of everything on 4th and 5th gear.
When i try accelerate just a little...the car and the engine change sound like it want it to do something but nothing happens...sometimes it start to accelerate but sometimes it does not...when the car changes the sound but it does not accelerate i would describe that sound as...some type of "chooking" or breathing? The sound is differenet and it changes to "normal" accelerating sound soon as the car starts to accelerate...maybe stuck/dirty throttle body?
BUT if i put "pedal to the metal" car behaves normaly and all those "problems" above are nowhere to be found.
IT IS really only when iam trying to maintain the speed or slightly accelerate.
Edited by Kapr
  • 10 months later...
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
