It is factory manual(5 speed)
The lag is "most" noticeable on 4th gear but it can stil "lag" on 3rd or 2nd...but on the 2n/3rd it is really like "milisecond" loss of power but gas pedal reacts normally.
And it not do that all the time...the "loss of power" is only sometimes and the "i dont know what you want me to do" on 4th is happeing often like the just do not react to the gas pedal(it reacts i can feel/hear it but like nothing happens for a moment)
But as i said it i only a cruising problem and when i try to maintain the speed.
When i drive it "harder" the car behave as it should...
Edited by Kapr
You really need a diagnostic cable and logging of core ECU parameters to get to the bottom of this.
  • Thanks 1
In my experience the MAFs are pretty robust in these, mine is original and with 255k on it. I did re-sodler the joints at one point but that wasn't my issue, it was the CAS. I would even take a punt at getting a used original MAF from yahoo auction if mine was suspected of funny business - there's one right now at about EUR 50.
You said your coils were splitfire, but how old are they? They will fail just like the OEM ones and many have 100k+ kms on them now. I thought splitfire went out of business a while ago?
The parts GTSBoy mentioned earlier really shouldnt be too expensive. I went ahead and just threw those exact parts at the car for preventative maintenance - OEM coils/plugs/harness, soldered MAF, rebuilt CAS and Walbro - and, touch wood, it's running fine.
All this stuff won't be so expensive and you should really expect to replace them anyway on a 25yr old car.
  • Thanks 1
@joshuaho96 Do we need any "special" software? I know(99%) that the car has no OBDII port and that i have some extension cord to the interface to OBDII
@GoHashiriya
Can you send me the link? I do not see that(it is friday so maybe it was sold)
Yeah they were used but i dont know how many km they done but i presume that if some of the coils gone bad the car would run on 1/X cyl less same as the problem with the connector?
As for the parts...yeah coil are old splits...plugs and harness is brand new...MAF is OEM and upon inspection looks good...connector to that too. CAS i rly dont know(can it do that?)
For the info i have.
I took the car to the highway and the symptoms are that most noticeable "lack" of everything on 4th and 5th gear.
When i try accelerate just a little...the car and the engine change sound like it want it to do something but nothing happens...sometimes it start to accelerate but sometimes it does not...when the car changes the sound but it does not accelerate i would describe that sound as...some type of "chooking" or breathing? The sound is differenet and it changes to "normal" accelerating sound soon as the car starts to accelerate...maybe stuck/dirty throttle body?
BUT if i put "pedal to the metal" car behaves normaly and all those "problems" above are nowhere to be found.
IT IS really only when iam trying to maintain the speed or slightly accelerate.
Edited by Kapr
  • 10 months later...
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
