Hi All,
I have a Skyline V35 with VQ25DD engine (215000km) that has engine noise.  The internet says its probably the timing chain, and it sounds like it to me. Runs OK otherwise. Is it possible to verify this is the cause before spending too much time/money on it? Am thinking perhaps I remove the small covers on each side of the timing chain cover (over the camshaft sprockets) and look inside. Not sure what to measure once I'm there however.
Assuming it is the timing chain I see a couple of options:
1. Fix the chain. Does anyone have any recommended kit brands and/or suppliers?
2. Replace the engine. Not many good ones around however. Is it possible to fit any other engines eg VQ25DE or perhaps a 3.0 or even 3.5L variant? Not too interested in spending a lot of time reprogramming ECUs.
David
25 minutes ago, Spoddy said:
Hi All,
David
Use some rubber hose to narrow down where the noise is coming from. I couldn't tell you for sure whether there are any easy direct swaps but most likely you're going to need a new ECU at the very least.
You're not swapping a 25DD with any other engine without it being a big exercise.
A proper timing chain inspection requires the front covers to come off so you can see the state of the tensioners and guides (which might be worn) and assess the amount of chain stretch.
See if the noise goes away when you turn the AC off.
My mate was sure it was the timing chain on her 350Z but one day she turned her AC off and the noise was gone. Only make that awful noise when the AC was on.
I assume clutch plate on the AC was the problem.
Not the timing chain. So she sold the car in winter. Rude as.
I spent a bit of time trying to find the source of the noise, with and without a piece of garden hose. I dont think its the timing chain, I think its coming from underneath the intake plenum on the passenger side. Am guessing its an incorrect valve clearance. I'll take the intake plenum and rocker cover off tomorrow and poke around with feeler gauges.
I see it uses shims. Are these hard to get? Where do you get them from - is amayama.com OK or is there somewhere better? I guess I'll also replace the spark plugs and I'll probably need some gaskets.
Edited by Spoddy
poor terminology
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
