9 hours ago, niZmO_Man said:
$5k each pipe thanks
Yep....but it is so much better than not being able to have it at all.
If someone wants to start 3d printing them I'll take 3
  • Like 1
I had a old Blitz BOV on my old boat, it leaked "alot" under boost
It was replaced with a Turbosmart one if I recall correctly and the Blitz one went in the bin
You don't have one at all on your car?
Yeah the rally car is off the road until our local motorsport body decide what changes they are going to make to cage regulations, and the one currently on it is cracked after a crash. I do have a lead on one nearby though :)
  • 1 month later...
What do you mean it leaked under boost? How can you tell?
I had a smoke/pressure test done at Unigroup engineering years ago
https://gfb.com.au/tech/tech-articles/15-smoke-testing-boost-leaks/
That was at least 15 years ago though, my memory ain't what it use to be
I just remember them saying that the Blitz valves were junk and had a bad habit of leaking
  • 9 months later...
On 6/25/2023 at 8:34 PM, GTSBoy said:
Well, a big chamber at whatever pressure the turbo inlet duct is at, which can be anywhere from atmospheric to a moderate level of suction. Remember, you do not want low pressure between your air filter and your turbo because that is stretching out the air available for the turbo to ingest. Any lower pressure than atmospheric at the turbo inlet works against the pressure ratio that the turbo is able to create. PR2 when you start at 14.7 psi is >29 psi (absolute), which is a whole 14.7 psi of boost. PR2 when you start at only 13 psi is suddenly only 26 psi (absolute). Subtract the 14.7 psi of the outside air from that and you only have 11.3 psi of boost.
What is PR2?
On 6/26/2023 at 5:45 PM, Duncan said:
So, your Blitz blow off valves release air to atmosphere (you can see the trumpet shape) who maximum duck noises. If you are happy with the how the car runs then no need to change anything, but they can cause stalling when returning to idle for example because air that went past the AFM never makes it to the engine.
Same goes, if there is nothing wrong with how it runs you could leave the BOV return in place and taped off, but I think it is trouble (or future trouble). The correct way to cap it off is a proper rubber or silicone cap with a hose clamp right back where it joins the intake and remove everything else.
Correct, the factory BOVs have outlets that connect to that pipe and send air back to the inlet when they pop open, so no metered air is lost.
Again, in the factory setup the cam cover breathers are connected to the inlet near the airbox. As the engine gets tired it will breathe more and more oil back into the intake, which is meant to be sucked into the engine and burned. In practice, over the years, some will collect at the low points in the intake and your BOV is one of those points. Since it looks like your front bar might be off, it would be worth disconnecting at least one side of the lowest intercooler pipes and seeing how much oil has pooled there
Revisiting this thread again x2... 1 year later. This car has been an ongoing project between life. But, I never removed the re-circ pipe. I know, shame on me. But since then, i took it to get tuned and only making about 280hp (lame) and i'm chasing a boost issue where the car wont boost past 7-8psi. Mac valve installed. Haltech Platinum pro with the map sensor.
This is the first time i've tackled the turbo side of things, but i have that side somewhat taken apart to chase the waste gate vacuum lines. And noticed this stupid pipe again. I'm peicing together the puzzle and @GTSBoy mentioned that it was a big vaccuum chamber and said a bunch of car math stuff that I couldn't quite follow the car math (im trying). You guys think this would be the culprit? between rotting vacuum hoses?
i'm making a DIY boost leak tester this weekend.
12 minutes ago, kevboost7 said:
What is PR2?
Pressure Ratio = 2. ie, 1 bar of boost (assuming 1 bat absolute pressure at the compressor inlet).
This is relevant because compressor maps do not have "boost" up the y-axis. They have pressure ratio.
Edited by GTSBoy
I do not think that the return pipe could be the cause of your particular troubles, unless perchance it is leaking in a lot of unfiltered and unmetered air (assuming your ECU is still using AFMs). And then it could be very bad, but it shouldn't prevent you making boost. Blow then engine up from running lean? Sure. But it would make boost.
You really needed to disconnect this thing from the turbo inlets and close those inlet ports off a year ago, and you should do it now.
Doing it this weekend. For sure this time. Thank you forum gods.
And im running map sensor now with the haltech. Still have the AFMs attached to the mushroom dome shaped air filter things
Is there a best practice on how to cap this? Its a 1.5 inch hole. I couldn't find standard sized caps, except some thin walled vinyl caps to fit the hole. Is there where you guys would cap it at? (circled in red) image.thumb.png.0069815bfb1346ba9626638271ea8e83.png
or would you cap it off the hose that attaches to this. As the re-circ pipe comes up from the intercooler and has a bunch more twists of connections and hardpipe that seperates into a soft rubber pipe to each turbo.
1 hour ago, GTSBoy said:
Right. Of course i knew the turbo inlet is sucking air. Just testing you.
On 6/13/2024 at 10:31 AM, GTSBoy said:
Shhh... Muricans don't understand the idea of metric so can't find half the stuff we have for modifying JDM cars 😛
  • Like 1
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
