Hi All,
Just wondering what people use for a space saver when upgrading their rims to 18inch?
Been looking around for something to replace the stock 16inch space saver as doing a few long trips and don't want to get caught out
Cheers,
Pete
Work out what overall size your new tyres are, then find anything that fits in the hole to suit. Example: my 275/40 17 R888R are 25.7" diameter, my spare is 205/65 15 with a 25.5" diameter. This gives me a difference on 1% diameter which "should" be fine with 99% of cars. You don't want 3% or over. https://www.tempetyres.com.au/tyre-size-calculator
I just have the standard one, it has been fine (for short distances) even with bigger tyres (I run 245/45/18).
The bigger issue is that the standard spare doesn't fit over big front brakes, so despite GTSBoy's good advice, I have to run it on the rear. Have done so a few times without issue, just take it easy and change as soon as you can
Interesting, I have been told the opposite and to avoid running a spare tyre in the front. And shuffle a good tyre from rear to front if necessary. Mostly because there is more weight in the front, more demand on it in corners and also in general when braking. It doesn't seem very safe to run a puny spare in the front when there is a lot riding on it.
  • Like 1
Thanks for all the replies guys..
The Bogan
- Thanks for that link, I checked it out and 1.07% difference to one space saver I've been looking at which is off a 370z.
GTS Boy
- 4WD.
Duncan
-I'm in the same situation now, as I upgraded to r34gtr vspec2 brakes since last using the stock space saver.
I haven't trial fitted at the back yet, I assume it may foul the calliper as it sits further away from the hub to accommodate the bigger disc?
I've ran the stock 16" space saver once when I had a puncture on the rear left (had r34gtt callipers at the time), didn't go over 60kmh and only needed to drive about 10km distance.  Could really feel the car tilting toward the left rear. I dint like it at all.
Soviet Merlin/GTS Boy
- I haven't heard that before regarding the position of the space saver...thanks to you both for raising that point.
Just went and double checked my tire size, I'm running 245/40/18.
Regarding the 370z space saver I saw it is 145 / 70R18 107M.
However in regard to hub diameter, apparently 370z is 66.1mm.  Where as Stagea/Skyline is 66mm diameter.
I've seen a couple of websites contradict these diameters in recent days in further searches, advising 66mm on Stagea/Skyline/370z or 66.1mm for all three. (grrrrrr).
That leads to more questions ie.
What is the definitive hub diameter of these vehicles?
Could you run the 370z space saver (66.1mm) on a Skyline/Stagea (66mm) hub if those measurements are correct?
Would it cause too much pressure on the studs without that snug hub fitment and cause them to crack or snap?
Would the space saver run in an elliptical manner as not centred on the hub correctly even by .1mm?
ps. I've got r34gtr rims.
Edited by Stagea_Neo
I run 32 GTR brakes on the rear, and the stock space saver fits over them fine. It is the 350mm ATTKD 8 spots that doesn't fit.
There is absolutely no issue using a wheel that fits over the hub, even if the hub ring is not correct (obviously you cannot mount the wheel if it's bore is smaller than the hub size.  The hub/wheel bore is just to make it easier to fit the wheel, once it is on the pressure of the wheel nuts on the stud clamping the wheel to the hub face hold it in place.
If they were day to day rims with a bore mismatch you can buy hub centric adapters but don't lose a second's sleep with a temporary spare
  • Like 1
Thanks Duncan, that gives me re-assurance in possibly going a 370z space saver.
6 hours ago, Bodella said:
I have R34 GTT brakes front and back had to go with 370z space saver, no problems with using front or back.  Note it doesn't fit in the spare tyre well.
Cheers Bodella, thought that maybe the case regarding tyre well.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
