Hey everyone,
I'm looking for some advice with a dilemma I'm having on choosing which direction I should go with upgrading my RB25DET's oil pump.
The current one is an N1 with a billet gear, and I wouldn't know whether the backing plate is factory or aftermarket as I bought the engine from the previous owner who had it built.
My first reason comes down to my own fear and uncertainty created from all of the horror stories I've heard about N1 pump failures although I know half of them are due to dodgy installation, and my second reason is that I feel that the capable power figure for my current fuel and turbo setup would be right at the edge of what the N1 can safely handle as moving forward I'd like to have the headroom to aim for bigger power safety with the piece of mind.
Originally I was considering going with a Nitto pump until realising that the whole engine would need to be disassembled as the crank snout would require machining to suit an upgraded crank collar to pair with the pump . Which obviously isn't a viable option as it's already a brand new built engine that had just only finished being run in for 1000km before I bought it.
However I've come across a examples of RB's running external wet sump oil pump setups instead which has sparked my interest in them, such as this kit from Ross Performance
https://golebysparts.au/products/nissan-rb-ross-lh-mounting-single-stage-external-oil-pump-kit-race-series-damper-306500-104?variant=15660827246701
as I've been thinking about if this alternative could be worth it rather than the expense and time that would be involved with the original idea?
I'd love to hear any opinions/suggestions yous may have to offer,
cheers.
https://www.sau.com.au/forums/topic/484484-oil-pump-upgrade-dilemma/
Just run oil pressure to your ECU and shut down the motor if you lose pressure. Most N1 pumps in the world don't fail, the biggest risk factor seems to be bouncing off the rev limiter like a foo.
Of course if you are thinking big big power (you didn't really give a figure above) then you should be changing to a different oil pump setup as the fundamental design from nissan was not great for quadrupling factory power....external wet pump is better a bit of a half pregnant option, dry sump is the way to keep a big $$ engine safe
  • Like 2
You would assume a crank collar would have been fitted during the build process.
  • Like 1
Sorry for the late responses.
I left that out by mistake Duncan, my bad mate. The power I want to make for now is between 600 - 650hp ish (it hasn't received a power tune post run in) and my ultimate goal I'd like to eventually achieve would be 750 - 800hp if safely possible, which is why I'd like some headroom with the pump.
I have looked into dry sump kits as well but honestly speaking that wouldn't be an option within my means, unless you could recommend a cost effective way to piece one together?
I also know an external wet sump system isn't a full measure compared to dry sump, but how would one stack up against other aftermarket internal oil pumps? Between the two which would you suggest, and what would be the pros and cons of each?
Thanks.
I'd like to, but I spoke to the original owner the other day to ask him and he wasn't sure at all but said he would ask the engine builder, which is making it less likely.
  • Sad 1
Thanks.
Regardless of what oiling system you use, the key is to setup limits and cuts based on oil pressure. I have tonnes of cuts and limits on mine. Duncan's advise is spot on. You dont need dry sump for 800hp. If you are really paranoid, then add Accusump or some sort of oil accumulator to the mix.
  • Like 2
I know some people have gone the external pump with a wet sumo route, but I use nitto internal pump (which seems to be very similar to the Tomei pump). A external pump requires a crank mandrel to drive it, mounting and an extra belt to throw or misalign, I don't see that is safer with a wet sump
  • Like 2
Thankyou both Predator1 and Duncan for advising me and my apologies again for yet another late response, I don't mean to make a habit of it.
I knew that it was probably a long shot but due to the high chances that an aftermarket crank collar wasn't fitted when the engine was built, I couldn't help hoping that a external wet sump system might be the workaround for the engagement issues that the stock collar has with conventional pumps, as well as a solution wouldn't require engine disassembly.
I'm still quite the long way off from my project running and driving as the engine has to go in out a fair amount of times for test fitting and fab work which could take a good while, but once I get closer to that stage when I'm more able too, I'll cop it on the chin and get a collar fitted and a Nitto pump like originally planned.
    • Just to give an update coilovers passed without any issue!
    • Ducan , yeah sure mate , the unit is https://www.carlinkit.com/ambient TBox Ambient -  plugs straight into the USB C and it runs as a android  unit and you can link your phone to it via Bluetooth , but it only allows for one phone at a time. you can download and apk files you want and load it on there , I downloaded a basic maps apk (OsmAnd+ — Maps & GPS Offline) so I can run navigation without data usage , its not as good at google or wazes but it works fine for what I need. I can put up screen shots if you like. Cheers Pac
    • Hey Team , just got the Fujitsubo unit installed , not a big db difference but it does sound better across the rpm range , I have the front pipe on order I'll post a video with sounds when that has also been installed.
    • The gearbox in my R32 GTS4 (now with RB25DET) has just over 300k on it . Life includes some track time. Has had one change of oil in its lifetime. I rev match on down changes. I don't have any problems with synchros or gear crunching.
    • Currently advertised with some A4 flyers up at work for $30k ono Will detail it next week, and get some good picks for carsales, then put the cover back on and put it back on the tender until someone comes to look at it No real hurry to sell, in saying this I would like it gone with in 6 months as I am retiring in May 25 and lose the ability to store the car undercover in a secured site, plus as we are moving out of Sydney the potential buyers market will be more limited https://www.sau.com.au/forums/topic/485907-2002-vx-ss-commodore-30000-ono/
