Hey all! I was wondering how much kw I would be looking at after my build Is complete!
Rb25det
Spool imports rods
Ross racing pistons
Race bearings
Billet crank
Mls metal head gasket
Arp head, clutch, rear main bolts
Nismo 1000cc injectors.
Larger fuel rail
Fuel regulator
Walbro 460lph
Exedy 690mn sports clutch and lightweight flywheel wheel.
R35 coil pack.
Gt3582
Haltech platium
Wideband, fuel, oil, coolant, knock, afr sensors
Laptop in passenger seat for peace of mind.
Upgraded exhaust obiously.
Screamer pipe
52mm external gate.
Front mount intercooler fenix
Fenix fat radiator.
Fenix twin rad fans
Last but not least.
Carbon fibre fuse box
https://www.sau.com.au/forums/topic/484487-forged-rb-power/
Thank god for the laptop in the passenger seat.
fuse box is going to be minimum 40kw.
gt3582 what?
what size exhaust?
what sort of manifold?
What fuel?
how long is a piece of string?
seriously search the dyno results thread. Things like this have been covered many times before
https://www.sau.com.au/forums/topic/484487-forged-rb-power/#findComment-7976372
These things are the only things that really determine your power.
Gt3582
Can't make more power than the injectors will flow (which maxes out in the territory of 1000 engine HP on 98) and can't make more power than a GT3582 will at the boost and flow you'd get out on the top RH edge of the map against a 2.5l engine (whilst maintaining a reasonable compressor efficiency so it doesn't get all hot and stupid, of course).
This may or may not be a good choice.
https://www.sau.com.au/forums/topic/484487-forged-rb-power/#findComment-7976373
