Anyone had this issue before?:
i was trying to bleed the attessa (r33 gtr vspec) and the strange issue that I have is that the bleed mode of the pump does not work. Ive done it 2 years ago and it was working. so when i disconnect the white connector under the dash the pump only starts if i turn ignition on, but when opening the bleeders it wont start on loss of pressure. if the connector is connected the pump won't do anything no matter what.
also strange is that there is only very little fluid coming through the diff bleeder, as there is no pressure. On the other hand there is good pressure on the transfercase bleeder.
I have no ECU connected, never touched any wiring on the attessa sytem and fluid level is ok.
anyone can help?
anyone can help?
I'm not sure I understand. When checking the factory service manual it explicitly says you must have the ignition switch on in order to have the pump run. Have you checked for codes on the ATTESA unit? I wonder if your pressure switch is working as intended. The bleeder mode is super simple, just running the pump to reach target pressure and switching off once it does. I'm pretty sure you don't need anything from the ECU either. Lack of fluid flow in your diff might be something clogged in the system but I haven't tried bleeding a known good system yet to see how much fluid should come out.
thanks for the reply!
yes IGN was on when trying it and I also know how the bleed mode should work. My problem is that the pump wont turn on if I open the bleeder. Normally I should give it 1 sec blurps to bleed but it simply does not do anything when I open any bleeder.
Where can I see codes on the attessa unit? like directly on the unit in the trunk?
clogging shouldnt be an issue as the system was not taken apart. i only diconnected the line to the back of the trans as I had the engine out for a rebuild.
Codes should blink out on the control unit in the trunk yes. You might be able to try and ground terminal 4 on the Consult connector without the engine running to get the codes to blink out, or maybe it'll just do it regardless of whether any terminals are jumpered: https://sites.google.com/site/tyndago/gt-rattesainfrormation
I would also try and see what's going on with your pressure switch with a multimeter.
Thank your very much!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
