Anyone had this issue before?:
i was trying to bleed the attessa (r33 gtr vspec) and the strange issue that I have is that the bleed mode of the pump does not work. Ive done it 2 years ago and it was working. so when i disconnect the white connector under the dash the pump only starts if i turn ignition on, but when opening the bleeders it wont start on loss of pressure. if the connector is connected the pump won't do anything no matter what.
also strange is that there is only very little fluid coming through the diff bleeder, as there is no pressure. On the other hand there is good pressure on the transfercase bleeder.
I have no ECU connected, never touched any wiring on the attessa sytem and fluid level is ok.
anyone can help?
anyone can help?
I'm not sure I understand. When checking the factory service manual it explicitly says you must have the ignition switch on in order to have the pump run. Have you checked for codes on the ATTESA unit? I wonder if your pressure switch is working as intended. The bleeder mode is super simple, just running the pump to reach target pressure and switching off once it does. I'm pretty sure you don't need anything from the ECU either. Lack of fluid flow in your diff might be something clogged in the system but I haven't tried bleeding a known good system yet to see how much fluid should come out.
thanks for the reply!
yes IGN was on when trying it and I also know how the bleed mode should work. My problem is that the pump wont turn on if I open the bleeder. Normally I should give it 1 sec blurps to bleed but it simply does not do anything when I open any bleeder.
Where can I see codes on the attessa unit? like directly on the unit in the trunk?
clogging shouldnt be an issue as the system was not taken apart. i only diconnected the line to the back of the trans as I had the engine out for a rebuild.
Codes should blink out on the control unit in the trunk yes. You might be able to try and ground terminal 4 on the Consult connector without the engine running to get the codes to blink out, or maybe it'll just do it regardless of whether any terminals are jumpered: https://sites.google.com/site/tyndago/gt-rattesainfrormation
I would also try and see what's going on with your pressure switch with a multimeter.
Thank your very much!
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
