8:5;1 comp in ideal for boost. There are copper head gaskets that are custom made if you know the thinness to achieve 8:5:1.. 9;1 comp is fine… but you will be limited to how much boost you can run.
Www.coppergaskets.com.au. If your after one 👍
  • Haha 1
What’s the limit of boost at 9.0:1? Very curious to know.
  • Like 3
  • Haha 1
From my understanding you can achieve about 5 - 10 psi with 9:1 - 9:5:1 comp safely before it goes pop.. before you think this wack boost levels, you have to consider the turbo, dump back exhaust, fmic etc your going to use on your rb30.
what power do you want, and is it a 5sp or auto?
  • Haha 3
You can leave the stock comp and put it on e85 and run higher boost?
2 hours ago, FiXtUrE said:
Regardless to fuel it’s the boost/comp pressure that will determine if it gos pop or not.
what comp ratio do you think this thing has to run 100psi of boost?
  • Like 2
Lol… I doubt it’s running 100psi.
rb30 with 8:5:1 head gasket + stock mani with spacer adaptor to blolt on rb25 t03 (with ceramic wheel) and possibly stock dump depending where turbo sits + custom mid pipe + r31 house rb20det cat back + hr31 stock intercooler at a maximum 12 psi + nistune should the job with auto (400kw)
steel wheel t03 + r32 gtr or r31 house fmic + forgies with big boost, go for your life with manual if you can find a clutch up to the job 👍
  • Haha 1
Yeah I doubt these 6 second 200+mph cars are running the boost they say they are.
I mean look at this guy claiming he is running 90+psi of boost and a 250 shot.
Why can't they just be honest and say they are really running 12psi of boost.
  • Like 1
  • Haha 2
It's basically Hollywood isn't it? I mean look at this! You can see the car on the dyno, see the data from the log.... 600KPA target.
More like 82KPA target and a bunch of YouTube Hollywood magic showing fake numbers and fake data, right?
  • Haha 2
What the hell kind of crack smoking joke is this? That is literally double the power possible with a stock ceramic shitter. When I'm talking about shards here, they can either be what you are on, or the pieces of turbine. Take your pick.
  • Haha 2
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
