16 minutes ago, GTSBoy said:
Only if the CHRA is completely cracked through. Which doesn't happen.
only way really to find out is if I Dona coolant pressure test, disconnect the oil drain and see if coolant leaks from there?  Or the other option head gasket? But very unlikely as I just replaced it which leave maybe piston bores have a hairline crack? I dunno lost for words now.
 Did a compression test and all cylinders were even.
4 things come to mind.
1. Head gasket - which I just replaced, MLS 12mm with copper spray for extra seal. (Not losing coolant )
2. CHRA - leaking through turbo drain and into sump ( coolant pressure test will confirm this tomorrow )
3. cracked head ( been repaired and machined. ( didn't even reach operating temp before unnoticed coolant in oil pan)
4. block (piston bores cracked)
more investigating 🤦🏽
Edited by VL_Turbo
14 minutes ago, GTSBoy said:
No. That makes it more likely.
Thinking of maybe replacing the Nitto MLS gasket and replacing it with a Genuine Nissan head gasket.
only went Nitto MLS due to it being a 1.2m thickness to reduce comp.
you never needed to reduce comp, but anyway.
How sure are you that the block surface was  all good ? It is a nightmare getting old gasket off. how did you do it?
copper spray isnt a normal thing to do. how much did you spray on? Have you done that before?
the chances of the turbo being the issue are so slim, but you may as well check.
(used knife sharpening block)
( knife sharpening block and sand paper on a block with wd40 and brake cleaner)
3 layers of copper spray, no, haven't done it before.
( wouldn't compression test eliminate all this, came up good all the cylinders were even?
Can you take us back to the start? Why were you doing the head gasket in the first place?
It is possible to get simple things wrong in this job....
Did you check every hole in the supplied head gasket matched the block and head orifices?
What procedure did you follow to tighten down the head? Do you know your torque wrench is calibrated properly? Are the head bolts still tight now?
Also I remember something about some blocks and needing to seal studs to the water jacket, not sure if that was rb30 though
Runt too much boost on a hot day with nearly 300,000ks on the motor. Old head gasket was worn out.
with the head bolts I followed the Gregory's manual. Used head stud and lube on the head studs.
will take rocker cover off and recheck the torque, I believe it was 97nm for head studs.
no idea about what you mean to seal head studs to water jackets?
Some head studs' drilled and tapped holes go through to the water jacket (On some motors. And Duncan was saying he didn't recall if RB30s were one of them, and I don't think they are).
On those motors you can't just screw them in, you have to apply thread sealant before you put them in to stop coolant coming up the bore of the stud hole and arriving in places where it is not supposed to be.
We might be able to advise you better with more detail. When you say
What did you notice happened, and what have you done since? For example,
did the car run hot?
did oil/water mix in the engine, and if so how did you flush the block, oil cooler (if fitted), oil/water interchange (if fitted), radiator?
did you use new head bolts/studs?
did you get the head checked for straightness?
after you prepped the block surface with a sharpening block/wd40, how did you check it for straightness?
- what was the procedure you followed, did you tighten then down in steps and was there an order to tighten the bolts from middle to outside?
Ran to half temperature, didn't get hot. Turned it off.
coolant and oil did mix, flushed the block via a bolt under the coolant line for the turb. No oil cooler fitted. But I did install a new trans cooler so avoided trans line connected to radiator.
Yes, new ARP head studs and bolts 11mm.
yes, crack tested, pressure tested, new valve stem seals.
checked with a straight edge.
Done compression test came up as follows
1- 111psi, 2- 115, 3-119, 4- 120, 5-120, 6- 115
done coolant pressure test and not leaking or losing coolant and definitely not losing coolant via turbo drain. Puzzled is understatement atm.😳
The extra detail does help. What was it that made you check for a headgasket issue in the first place if it never got hot?
I'm thinking it might be fine and the milkshake is just from the original failure. Try changing the oil again and see if it is getting better or still bad.
The coolant pressure test is a good check but it can miss an issue which only occurs when hot or at much higher pressures (like compression pressure)
  • Like 1
alot of white smoke came out of exhaust.
I'll get new oil now.
I'll put new oil and leave it idling for 10-15 mins, will have to bed the new cam in as well. (Stage 2 Kelford 226F).
2 hours ago, Duncan said:
absolutely, either a specific product or just throw some diesel in with the oil for 5 minutes.
I bought Penrite flush oil. Went online and I was told it can harm the engine?
this is my Nitto 1.2mm multi layer steel head gasket, can only go on one way right?
Edited by VL_Turbo
