Good afternoon all,
Recently picked up my crank that’s been in storage for a number of years now.
it’s been balanced, grub screwed & reground. By an unknown machine shop (I didn’t get the name from the last builder)
but not sure on the markings.
221111
000000
Without assuming too much I’d say the top numbers are conrod bearing clearances
and bottom numbers are mains? (Photo although poor quality shows markings)
I’ll know more once I check with micrometer & dial bore gauge against the block & conrods.
any help be greatly appreciated.
Regards.
My understanding is those numbers relate to Nissan's range of super-fine specs of standard bearings size rather than just 'here's a STD size bearing". So unless using forementioned Nissan's superfine range of STD bearings, and instead using any aftermarket bearing where you just get STD, or much larger oversize/undersizes, the numbers don't mean much..especially after work has been done on it.
I tried matching the numbers VS the workshop manual during one build...too hard, too expensive, gave up.
  • Like 1
Yeah just double checked a crank I have, that is the factory crank big end and main gradings. Details of the factory grades are on EN101 of the r32 manual.
They are of no relevance 30 years later of course
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
